Highest Mileage Journey... Who's in it for the long haul?
jeffhoward001
1 hour ago, John/Horace said:
 Did you add a block heater to the engine, or is in a garage over night, curious. Bad winter this year.
Block heater I keep it outside. I use synthetic oil so I don’t plug it in unless it’s below -20C or -4F. I have it on a smart timer that turns on 6hrs before I start it. The 6hrs is more for when it’s -30C or lower.
On a side note, since posting a few days ago it sounds like the power steering pump is now going. It’s whining after it gets hot. I think I’m going to take it in for this one as it looks to be pretty involved with not much people taking about it.
My son's '11 mainstreet awd now has 266,200 miles on it and going strong. Says he's going to keep it till the wheels fall off.
He now likes the idea of NO CAR PAYMENTS for his ride after a minor "fiasco" with his wife's '19 Jeep compass for maint. AND an 11% rate car loan!
My ram has a block heater, electric rack so no whinning hydraulic pump on start ups. Journey 3.6 pumps are burried and always noisy, it seems. Daughter in law's 2.4 is quiet and hi milage, but easy access, figures.
I would suck out the atr+4 first, make sure reservoir bottom screen is clear, brake cleaner spray works well. My fluid has been changed multiple times. Pump slightly loud, but tolerable still. Try a flush or two.
Edited by John/Horace
  • 3 weeks later...
I must have "jinxed" my son!
  On 2/15/26 while on his way to work at 5:15 am he hit a deer with "old red". Tore off the front bumper fascia and under plastics, but no damage to metalwork or composite header panel. The radiator popped out of it's clip mounts but did not get hurt to leak, so he made it to work all right. I went and swapped the cars for him with our 4 bangerfwd and limped his car home.
Being a bitter cold morning/day, all went well until I got 8 miles from home when something in the cooling system on the engine firewall side broke and lost all coolant. Longest 8 mile ride I've ever had( and coldest interior) to nurse it home. Needless to say until Spring and warmer and DRY days come, no real inspection/ repairs can be done. SO we are transferring ownership of the 4 banger to him (which he likes the car).
   NOW for my car situation, I AM getting through my friend a '17 crossroad that I posted of possibly buying in another thread here on the  site. $6.5grand, and it IS an AWD.
It is getting a lot of repairs in that price (VC gaskets/oil filter housing(aluminum), plugs and a new flex plate from damaged teeth for starter ring). I will have some electrical wiring repairs to do with the rear hatch lighting and back up camera, and probably the wires in the "rubber boot" area being the cause (no big deal for me). This summer, I'll put a hitch on it and wire for trailer.
Then the game plan is to go back to "old red" and see if we can put him back together at a reasonable cost, as my son would like to keep him IF POSSIBLE.
I Just got Thur spending a bunch of $$ on my 2014, new windshield $100 thru  Allstate ins., new tires went with some Pirelli scorpion 3 from discount tire,I  have never had this brand before but they are riding quiet and rated real good,I got a great deal due to one of my old tires having to be replaced due to a nail and they adjusted the other 3 out so out the door for $700 with tire warranties as well,,,had a trans service done to a broken bolt on the pan cover  that was done at the dealership but was covered up with enough permatex to keep the bolt head from falling off but it was done around 4 yrs and 60 k so I just had it fixed and fluid and filter  at the local transmission shop didn't want to blame or argue with the dealership,cost was around $300...So all set for a long time now I hope....
  • 2 weeks later...
Well it's 2 weeks later and the '17 is still at my friends shop.  He decided on putting on a new set of tires and a front wheel bearing, thus causing the delay due to other work running his shop.
Last Friday and Monday, I went over and checked out the rear hatch lighting and B/up camera issues and indeed found 12 broken wires in the rubber boot. I repaired them all and ALL is good now. The wife will LOVE the B/up camera, and may even start moving the car in reverse more now than just backing into our driveway (LOL)!
I'm hoping to have the car in my driveway this Friday, and will try activating remote start system with my alfaobd program (it didn't have that feature), I've already programmed a proper fob to the car, but am having trouble getting it to start on the second click on the fob... not sure if the used hood switch is bad or what just yet, so I'm going to try the working one from "old red" while he's in "hibernation". I had activated "old red" and the '14 we had for remote start, so I'm comfortable knowing I used the proper steps on the '17.
My son is really liking the '13 4 banger for it's added toys and better MPG than "old red".
STAY TUNED for further updates.....
  • 2 months later...
Mine has 174,000 and runs great. Its only had regular maintenance issues mostly, had a window issue but I fixed myself. Other than that it has been the best vehicle I have ever owned. I used to work in sales at a very prestigious Dodge dealership back in the day so I know Dodges and again I'm super proud of my Dodge and it's reliability.
My neighbor bought a Jeep same time..he's selling it in his front yard now LMFAO. GO DODGE!
Welcome to site. You must have the 3.5 engine, it's was pretty reliable unit. If you don't have  service records, do all the fluids right away, cheapest maint you can do in the long run. Especially if you have dripping leaks; can't tell fluid level without refilling sometimes.
4 hours ago, larryl said:
And it has a timing belt.......
Which as of yet, I have NOT read of anyone replacing according to year age or mileage. Stripped cog teeth or broken, means catastrophic ENGINE DAMAGE.
My 2016 RT AWD that I bought brand new has a little over 232k miles on it now. Currently working from home so not being driven much. Here’s the “extra” work it’s needed:
1. Engine tick- I had one bad rocker arm and a rounded cam lobe because I let it go way too long. Replaced all rocker arms, all lifters, and 2 of 4 cam shafts. Did myself during COVID shutdown. Took two days, but I had to wait for the cams to get delivered to finish.
2. cracked flexplate- replaced at dealership…not a cheap fix.
3. AC wasn’t blowing cold - replaced humidity sensor and it fixed the issue. cheap and easy peasy to do yourself
4. The part that rotates to push air through the selected vents- cheap and done myself.
5. driver door window/lock control switch panel - cheap and easy
6. coolant thermostat - was stuck open. annoying to replace yourself
7. GPS stopped working just out of warranty. A couple years later they were selling map upgrades at 50% off so I took a chance and it fixed that issue (not mechanical, I know but may help others)
8. headlights fogged up/collecting water (very recent) - replaced with after market headlights
9. dried out and broken windshield washer hose - broke nozzles trying to remove. Replace both
Supposed to be replaced every 100k miles. I had the same motor in my old Chrysler 300
1 minute ago, larryl said:
Well I replaced mine along with the water pump when I had my 09 RT just to be safe
I must have missed reading of your care in maint. for your past '09 ride. When I first came to this forum, there were many folks posting of having broken timing belt problems, and very few that I found of even supporting the need to replace according to the "book". Yes 100k miles or 7 years if I remember correctly, and an engine used in many Dodge models of the "era" and why I always "steered clear" of having one with the 3.5 and worse was the 2.7.
Even timing chains can wear out with bad luck, high milage, lack of maintenance.  Much easier to change a belt then a timing chain; always cheaper as well. My 2000 quad 4 chain tensioner never made 100k miles, and water pump ran off chain, brilliant.
The 2026 Honda Odyssey van still has a 3.5 v6 with timing belt. Kevlar reinforced belt and I'm sure most people exceed the 105k or 7 yr interval. Belt engines keep the engine oil a lot cleaner; no chain or gears in the oil flow.
My brother's 3.5 fca motor went beyond 200k miles...with belt and water pump changed. He drove it to an auto wrecker; rust killed it, not the 3.5 reliability. The 3.6 was bought in because of emmission regulations, I believe. Also a very decent engine.
  • 3 weeks later...
I have a 2017 2.4l engine that has over 650k miles. I do not know exact because it stops counting mileage at 999,999km which is 621369mi
i bought this vehicle in September of 2022 with 36,xxx, and by August of 2025 it no longer counted miles. Biweekly oil changes. Alternator replacement 1 time, spark plugs changed at 200,000k and spark plugs and ignition coils changed at 580k mi. Had a check engine light for p0420 from about 180,000 miles cleared code daily till I finally replaced it when I needed throttle body around 560k mi. These are the only repairs I made on this vehicle. Still drives great but I have noticed an oil leak from pan gasket in the last 70k miles.
Oh... is that all 🤣🤣🤣
Ashley must run Uber or some kind of delivery driving. The journey 2.4 is not the self distructing tiger shark four cylinder for sure. Most people do a crank sensor and electronic throttle body by 100-150k miles.
Cooling system manifold tends to leak by then as well. Not a difficult repair.
I wonder how many transmissions and and if starter still original, water pump?  Daughter in laws 2.4 oil pan also rotted out by 120k. It's only at 150k miles now, slight oil usage. It works pretty hard in the big journey body. Simple can be good in the automotive world.
The hour meter in the guage cluster should still be recording in the high milage 2.4 journey. Could do an approx milage calculation using that.
  • 2 weeks later...
I just joined the 200K club (miles) for the first time.  I've had 180's before, but finally turned a two.  😁
2014 DJ SXT 3.6 FWD
Normally we would have traded this car for a new by now, but I'm having trouble accepting the prices on new cars (bronco sport, escape, equinox, blazer, ...).  Dodge has nothing and I'm not a Jeep guy.  So we've been holding out.
The DJ is in the top 2 of the best cars we ever owned. It was definitely the right car, at the right time, at the right price, for us (new in 2014).  Another reason for holding out buying new is I really like the 3.6 6 banger engine in the DJ.  Its just smoooooth, with enough extra when needed.  New cars are 4 bangers with turbo, and even a 3 cylinder.  No way can I own a 3.  (Anything with a 6 cylinder options out at far more than I want to spend.)
Its had several of the typical DJ issues: been through 2 thermostats, power steering hoses and cooler, TCC solenoid, the front allusive squeak, and I think I'm due to replace the oil cooler for a second time.  Relatively speaking these are minor problems and I've learned to do the repairs myself.
I'm going to shoot for at least another 3 years so its due for a second round of maintenance: trans fluid, plugs, battery, serpentine, PVC, and tires.  It is getting a bit bouncy too.  We'll see...
Hopefully I haven't cursed myself by speaking nicely about the car (spoken as I spin 3 times, face north, make a cross with my fingers, and spit into the wind to thwart off gremlins.)
The way my family drives, all three of our journeys will break through the 200k mile barrier by mid autumn.
Rear struts are NOT FUN to change, and I like the aluminium T-stat and the aluminium oil filter housing.... basically ONE TIME and DONE with few worries.
But with 3 of these on the road....just don't get me discussing wheel bearing issue, I've replaced or had replaced 10 of the total 12 so far!
  • 4 months later...
Yesterday I hit my goal:
300,000 MILES!
I admit it was an arbitrary goal, but I have never had a vehicle endure that much mileage. As I said in a post above a few years ago when I hit 250,000, I'm not always the most gentle driver, but I did do my best to take care of DJ. And I think that is good advice for life in general, that when you take care of something, it lasts longer.
Based on the math, it should only take another ten years to hit 500,000. I don't know what the future holds for DJ and I, but I do know I've loved not having a car payment for the past ten years. ;)
