Laur Posted September 17, 2020 Report Share Posted September 17, 2020 no code, no turn over, no sound. is that panel saying my starter is dead? Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 17, 2020 Report Share Posted September 17, 2020 dont know what you are trying to show us? how old is your battery that would be my first thing to check or replace. good luck OhareFred 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 17, 2020 Report Share Posted September 17, 2020 No, your panel is saying your door is open and your seat belt is not on. 2.4journey2013, OhareFred and 2late4u 1 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 17, 2020 Report Share Posted September 17, 2020 Jkeaton,, LOL i was trying to be nice jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 18, 2020 Report Share Posted September 18, 2020 16 hours ago, 2late4u said: Jkeaton,, LOL i was trying to be nice Just stating the obvious....... 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Laur Posted September 21, 2020 Author Report Share Posted September 21, 2020 (edited) On 9/16/2020 at 10:47 PM, 2late4u said: dont know what you are trying to show us? how old is your battery that would be my first thing to check or replace. good luck sorry. the gear position is not normal. battery is Good, I also tried jump starting. Edited September 21, 2020 by Laur Quote Link to comment Share on other sites More sharing options...
OhareFred Posted September 21, 2020 Report Share Posted September 21, 2020 I know on Jeeps when that happened it’s a shifter malfunction, maybe the same? You could try disconnecting the battery for 30-45 mins, sometimes that clears weird electrical issues but this might require a trip to The dealer.... Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 21, 2020 Report Share Posted September 21, 2020 4 hours ago, Laur said: sorry. the gear position is not normal. battery is Good, I also tried jump starting. how do you know the battery is good??, journeys like a full charge to start, have a load check done on the battery to assure you have a good battery as just checking with a meter is not enough and yes you can have enough power for lights and radios and such and your journey wont start .....as it just happened to me a few months ago and my neighbor had a jump box for jump starting and even it wouldn't crank mine,called a tow truck and he did a battery load check and yes it was bad ,new battery and NO more problems...good luck and i hope it is just the battery that is bad for you.... jkeaton 1 Quote Link to comment Share on other sites More sharing options...
JohnnyRevs Posted September 24, 2020 Report Share Posted September 24, 2020 If the battery is good, the engine should at least try to start - if the voltage is over 12, it will usually turnover. If the starter is stuck you could try tapping the solenoid with a hammer - might be enough to free it (worked for me recently). IIRC, there is also a switch on the transmission that tells the ecu that its in Park and ok to start. Suggestions only I'm afraid as I do not have an auto. Good luck with it. John/Horace and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Laur Posted October 5, 2020 Author Report Share Posted October 5, 2020 I took the starter off and checked, it is working. I reinstalled it back. the engine turn over but no starting. do not smell gasoline at all. what should I check first? no engine code. How to check spark plug and coil? Quote Link to comment Share on other sites More sharing options...
larryl Posted October 5, 2020 Report Share Posted October 5, 2020 Could be fuel pump, also your timing belt if it's a v6 3.5 OhareFred 1 Quote Link to comment Share on other sites More sharing options...
Hidiety Posted October 6, 2020 Report Share Posted October 6, 2020 Bust out your owners manual an look at the section for fuses. There are 2 in the vehicle for ignition. 1 in the panel under the hood and 1 under the dash. Since you have power and a jump still won't turn it over that would be my slightly educated guess. 2late4u and OhareFred 2 Quote Link to comment Share on other sites More sharing options...
Dbloxham518 Posted October 8, 2020 Report Share Posted October 8, 2020 You could try tapping the starter. Mine just needed a little "hay wake up" tap a few weeks after buying it and it hasn't gone bad yet. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted October 8, 2020 Report Share Posted October 8, 2020 It’s turning over but not starting. CPS sensor can be bad, or timing belt has jumped, remove cover and inspect teeth on belt. OhareFred 1 Quote Link to comment Share on other sites More sharing options...
JohnnyRevs Posted October 18, 2020 Report Share Posted October 18, 2020 Well, if its turning over, try to narrow down the issue - you need spark, fuel and air. Have u plugged in a diagnostic scan tool? jkeaton 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted October 18, 2020 Report Share Posted October 18, 2020 It's been a month since this thread was started with NO response back from the OP. Stated NO code,NO turnover, NO sound. From his picture of the gear position, would lead me to think bad battery or cable connections(ground or positive). I've seen this a few times with Dodge family minivans. jkeaton and JohnnyRevs 1 1 Quote Link to comment Share on other sites More sharing options...
