Marc Howell Posted August 9, 2016 Report Share Posted August 9, 2016 I trial fitted my led lights to see what difference and its night and day. Just need to fit the resistor somewhere as the bloody thing get very hot. The R/H is standard, L/H is led 40w 4000Lm 6k output with a 50w 6Ohmj resistor. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 9, 2016 Report Share Posted August 9, 2016 I absolutely love mine. Quote Link to comment Share on other sites More sharing options...
HugoClement Posted December 3, 2016 Report Share Posted December 3, 2016 Did you change your DRL/High beam too? I was looking to switch to LED but I'm worried about the bulb not being able to switch between these two intensities. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 4, 2016 Report Share Posted December 4, 2016 Using LED's with DRL's, the bulb intensity is the same as with the high beams in. It takes much less voltage to "turn on" the LED bulb so it is on normally with the DRL's. so you are essentially driving around with your high beams on all the time. greenturtle 1 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 4, 2016 Report Share Posted December 4, 2016 Do you get any flickering with these bulbs? I tried led high beams but with the car running the passenger side flickered so much it was distracting. I tried resisters, a replacement bulb, and switching bulb sides. Same results. Only the passenger side. Weird. I have an 09 btw... Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 4, 2016 Report Share Posted December 4, 2016 Nope. Plug and play. No issues at all. Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted December 28, 2016 Report Share Posted December 28, 2016 Real smart.....drive around during the day with the high beams on blast cause you want "LED". So pointless haha Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 28, 2016 Report Share Posted December 28, 2016 Whos doing that? I believe the question was would leds work as drls and the op was basically told no. Did you misread! JohnnyRevs and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 29, 2016 Report Share Posted December 29, 2016 When I went to LED's, I turned my DRL's off so I wouldn't be driving around all day blinding people. There is a certain amount of common sense that needs to be referenced when changing OEM headlight bulbs. OhareFred, 2late4u and JohnnyRevs 3 Quote Link to comment Share on other sites More sharing options...
darrenm Posted February 1, 2017 Report Share Posted February 1, 2017 Nice. Bought mine on ebay and had some flickering issue so I decided to remove them. Quote Link to comment Share on other sites More sharing options...
Steven Harshbarger Posted February 1, 2017 Report Share Posted February 1, 2017 Are they straight plug and play? I'd be interested in upgrading the headlights on my DJ. Although they're not bad now, i'd consider making them better. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 1, 2017 Report Share Posted February 1, 2017 (edited) Bought these and they are plug and play. No relays, no load resisters, no flickering, etc, etc. Plugged them in and they worked perfect right off the bat: https://www.amazon.com/YITAMOTOR-2pcs-Headlight-Conversion-6000K/dp/B017LW2V42/ref=sr_1_1?ie=UTF8&qid=1485960786&sr=8-1&keywords=YITAMOTOR+2pcs+Cree+60W+9006+HB4+LED+Headlight+Conversion+Kit+High+Low+Beam+6000K https://www.amazon.com/YITAMOTOR-Headlight-Bulbs-8000LM-Xenon/dp/B017KC049W/ref=sr_1_1?ie=UTF8&qid=1485960870&sr=8-1&keywords=YITAMOTOR+2pcs+Cree+9005+HB3+LED+Headlight+Bulbs+High+Beam+80W+8000LM+Xenon+White+6000k+Fog+Light+Lamp Bought these for the fog lights. Again, plug and play. https://www.amazon.com/SiriusLED-5202-2504-PSX24W-Projection/dp/B00MQEIRTO/ref=sr_1_1?ie=UTF8&qid=1485960617&sr=8-1&keywords=SiriusLED+Super+Bright+White+5202+2504+PSX24W+30w+Projection+LED+Fog+Light+DRL+6000k+White Edited February 1, 2017 by jkeaton Quote Link to comment Share on other sites More sharing options...
MoxiRdz Posted April 21, 2017 Report Share Posted April 21, 2017 On 2/1/2017 at 9:39 AM, jkeaton said: Bought these and they are plug and play. No relays, no load resisters, no flickering, etc, etc. Plugged them in and they worked perfect right off the bat: https://www.amazon.com/YITAMOTOR-2pcs-Headlight-Conversion-6000K/dp/B017LW2V42/ref=sr_1_1?ie=UTF8&qid=1485960786&sr=8-1&keywords=YITAMOTOR+2pcs+Cree+60W+9006+HB4+LED+Headlight+Conversion+Kit+High+Low+Beam+6000K https://www.amazon.com/YITAMOTOR-Headlight-Bulbs-8000LM-Xenon/dp/B017KC049W/ref=sr_1_1?ie=UTF8&qid=1485960870&sr=8-1&keywords=YITAMOTOR+2pcs+Cree+9005+HB3+LED+Headlight+Bulbs+High+Beam+80W+8000LM+Xenon+White+6000k+Fog+Light+Lamp Bought these for the fog lights. Again, plug and play. https://www.amazon.com/SiriusLED-5202-2504-PSX24W-Projection/dp/B00MQEIRTO/ref=sr_1_1?ie=UTF8&qid=1485960617&sr=8-1&keywords=SiriusLED+Super+Bright+White+5202+2504+PSX24W+30w+Projection+LED+Fog+Light+DRL+6000k+White Did you use same model for both low and high beams jkeaton? I just click on both links and amazon shows me the same model 9005. Thanks! Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 21, 2017 Report Share Posted April 21, 2017 Links are old. No. The low and high beams use different bulbs. Bulb sizes can be found in the bulb size sticky in this section. Quote Link to comment Share on other sites More sharing options...
MoxiRdz Posted April 21, 2017 Report Share Posted April 21, 2017 10 minutes ago, jkeaton said: Links are old. No. The low and high beams use different bulbs. Bulb sizes can be found in the bulb size sticky in this section. Ok, thanks! Quote Link to comment Share on other sites More sharing options...
MoxiRdz Posted April 21, 2017 Report Share Posted April 21, 2017 (edited) 55 minutes ago, jkeaton said: Links are old. No. The low and high beams use different bulbs. Bulb sizes can be found in the bulb size sticky in this section. I have a problem!!! jkeaton.. Apperently they have two models for 9005 and one model for 9006 (in the link provided)... For 9005... (2 Pieces) of complete 60W 6400LM Cree LED 9005 HB3 6000K White Headlight Kit 2 Pcs of Upgrade 9005/HB3 LED Headlight.9005 LED Car Headlight Kit COB Chip 80W Auto Car LED For 9006 9006 HB4 80W All-in-One 360° LED Headlights Cool White 6000K Low Beam / Fog Light Bulbs Super White 8000 Lm, Fast delivery in 1-3 business days. High power: Mini Fans inside, 4 COB LED chips per bulb, LED Drive Ballast at the bottom of the bulb Which one is exactly what You have for each model? I thought You had both cree.. which I can not find from Yitamotor (in Amazon) https://www.amazon.com/dp/B01GDTE6II/ref=twister_B01GDW37JY?_encoding=UTF8&th=1 Edited April 21, 2017 by MoxiRdz Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 21, 2017 Report Share Posted April 21, 2017 (edited) YITAMOTOR 2 X HID White Gold 9005 CREE 60W WHITE LED HEADLIGHT Conversion Kit Bulbs Lamp YITAMOTOR 2 X NEW HID White Cree 60W Gold 9006 HB4 LED Headlight Conversion Kit Bulbs US This is what my order history shows. Edited April 21, 2017 by jkeaton Quote Link to comment Share on other sites More sharing options...
MoxiRdz Posted April 21, 2017 Report Share Posted April 21, 2017 Thanks! I think 9006's are no longer available... I will try 80 watts....Do You have any experience with COB vs CREE ?? Or 60 watts vs 80 watts? Quote Link to comment Share on other sites More sharing options...
Bryman31 Posted September 3, 2017 Report Share Posted September 3, 2017 any update on this? Quote Link to comment Share on other sites More sharing options...
Bryman31 Posted September 3, 2017 Report Share Posted September 3, 2017 i cant update above post............. i was looking at these, mainly cause a buddy has them in his truck and its got some good light output.......... http://www.opt-7.com/fluxbeam-x-led-headlights/ Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 10, 2020 Report Share Posted January 10, 2020 well one of my led crapped out 9006 low beam so i ordered off amazon a set of 9006 LED Headlight Bulbs Mini Sized 80W 16,000LM Per Pair CanBus Ready, AUXITO 9006/HB4 Headlight LED Bulb Conversion Kit, 6500K Xenon White, Pack of 2 Price: $59.99 they are a bit stronger then my last set so far so good they are made great and they are compact so easy to install actually was worried as before i got them i got email from manufacture For very few sensitive vehicles, anti flicker harness may be required in addition,,,but was pleased that is not necessary on our journeys, they include instructions on how to install the lights so you get them right....just hope they last,they are a lot brighter tan my old set as i installed one and then checked them at night time compared to the old one still in the other side was brighter and actually light pattern was lower then the old set....... Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 10, 2020 Report Share Posted January 10, 2020 So you got a few good years out of them? Not a bad lifespan for headlight bulbs.... Quote Link to comment Share on other sites More sharing options...
rozey66 Posted May 8, 2020 Report Share Posted May 8, 2020 On 1/9/2020 at 8:02 PM, 2late4u said: well one of my led crapped out 9006 low beam so i ordered off amazon a set of 9006 LED Headlight Bulbs Mini Sized 80W 16,000LM Per Pair CanBus Ready, AUXITO 9006/HB4 Headlight LED Bulb Conversion Kit, 6500K Xenon White, Pack of 2 Price: $59.99 they are a bit stronger then my last set so far so good they are made great and they are compact so easy to install actually was worried as before i got them i got email from manufacture For very few sensitive vehicles, anti flicker harness may be required in addition,,,but was pleased that is not necessary on our journeys, they include instructions on how to install the lights so you get them right....just hope they last,they are a lot brighter tan my old set as i installed one and then checked them at night time compared to the old one still in the other side was brighter and actually light pattern was lower then the old set....... which orientation (rotation angle) did find worked best? Quote Link to comment Share on other sites More sharing options...
mikecast Posted November 30, 2024 Report Share Posted November 30, 2024 looking for a good high low beam leds bulbs for my 2014 Dodge journey SE 2.4l. any help Quote Link to comment Share on other sites More sharing options...
diymirage Posted November 30, 2024 Report Share Posted November 30, 2024 Look up fahren. They got a good rep Quote Link to comment Share on other sites More sharing options...
