Hot air blowing on one side when air conditioning is on
I have a 2013 journey crew and when the air-conditioning is turned on I get cool air on the left side and hot air on the right. Had the same problem last year and it corrected itself. Just wondered if anyone on the forum has ever encountered this problem?
Thank you for any help you can give.
  • Official Dodge Support
Hi davidmack4044,
We're sorry to hear that you are having this air conditioning concern. Have you brought this to the attention of your dealer? Please message us if additional assistance is needed.
Darlene
Dodge Social Care Specialist
  • 3 weeks later...
On 5/29/2018 at 7:41 PM, Jeframos said:
I am having the same problem now. I am going to see the dealer asap. My concern is that its out of warranty already. Cross fingers on what will happen.
Hi Jeframos,
Please feel free to send us a PM with your VIN, mileage, and dealer if you need additional assistance while at the dealer. We are happy to assist.
Darlene
  • 10 months later...
Just had the same problem.  It is a blend door actuator.  Had to be replaced.  70 bucks for the part and 80 for labor.
It started last year, fixed itself, then came back.
Works like a top now.
Apparently youtube has some videos on how to replace it, but I didn't have the time to do it.  Also, I was afraid I would break it or something else while trying to save a few bucks.  Sometimes it is easier to just get something fixed at the dealer.
I am almost at the point where I could write a book about problems and repairs to the Dodge Journey, but I don't have the time to write it.
mechanical-idiot
  • 5 years later...
  • 3 weeks later...
Hello, I am new to this forum.  But I do have a concern with my Climate control.  AC work great up front, but blows heat in the back.  I didnt realize it until one day, my 2 year old kept saying he was too hot and was sweating up a storm.  I checked the air and it was full blast heat on him.  Seeking advise to repair.
I have a 2016 journey that has this problem.  I didn't have an issue last year but all of a sudden when I turned on my AC yesterday, hot air was blowing from the passenger side and cold air on the drivers side.  I'm not sure if my Warranty covers this issue.?
depends on what kind of warranty you purchased and also what ded you have as mentioned the part isn't that expensive and takes about .5 hr to replace,,,as mentioned check out YouTube the part I held in with 2-3 screws just hard to reach kind of awkward try tapping it with a long screwdriver they tend to stick in the closed position P.S. it has been mentioned to only use OEM blend doors actuators instead of aftermarket/amazon parts that don't last...just a recommendation
Edited by 2late4u
extra info
  • 1 year later...
  • 1 month later...
On 6/7/2025 at 12:45 PM, davibentim said:
What are other things to check other than the blend door actuator? Replaced mine and it's still the same issue.
Bump.  Good question.
The air started blowing hot on the driver side while still blowing cold on the passenger side.  Everything on the internet says it's most likely the blend door actuator.  I replaced the driver side blend door actuator and still the same problem.
I then used a recharge kit and that seemed to fix it for a couple days.  Now the air is blowing warm-to-hot on both sides and takes forever for just the passenger side to get cold.
Any advice on how to proceed next would be greatly appreciated.
