Cbrooks45 Posted January 15, 2015 Report Share Posted January 15, 2015 Does anyone know how to disable the seatbelt chime on a 2014 Journey? Yes, I wear my seat belt. but sometimes when you have to take it off to adjust your seating on long drives and it starts chiming it is freaking annoying. I did it on a 2005 Caravan. Hoping these have the option to do it as well. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 15, 2015 Report Share Posted January 15, 2015 (edited) Other than electrically disconnecting it, nope. It could not be on that long if you are just adjusting your seating. Edited January 15, 2015 by jkeaton Quote Link to comment Share on other sites More sharing options...
Cbrooks45 Posted January 15, 2015 Author Report Share Posted January 15, 2015 I dont like it at all. With the caravan it was turn key twice spin around on one leg kinda thing but it worked. Was hoping for the same on this but sounds like I am out of luck. Quote Link to comment Share on other sites More sharing options...
Dee Posted January 15, 2015 Report Share Posted January 15, 2015 I have a 2015 SE, my seatbelt doesn't chime at all. Nothing I did, that's the way it came? Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted January 16, 2015 Report Share Posted January 16, 2015 It is annoying. Especially on long road trips when the wife has to unbuckle to help the kids in the back with something for a couple minutes. Constant dinging... Quote Link to comment Share on other sites More sharing options...
bramfrank Posted January 16, 2015 Report Share Posted January 16, 2015 There is a simple procedure that was documented in the manual from my '11 - they seem to have deleted it from the manual that came with the new car, but te procedure still works - I have the 'belt minder' disabled - I wish it also switched off the display reminder - I have to keep pressing 'back' to see my fuel economy. Quote Link to comment Share on other sites More sharing options...
Milous Posted January 16, 2015 Report Share Posted January 16, 2015 Does anyone know how to disable the seatbelt chime on a 2014 Journey? Yes, I wear my seat belt. but sometimes when you have to take it off to adjust your seating on long drives and it starts chiming it is freaking annoying. I did it on a 2005 Caravan. Hoping these have the option to do it as well. The following sequence of events must occur within sixty (60) seconds of the ignition switch being placed in the On position in order for the programming to be completed successfully. 1.With the ignition switch in any position except On or Start, buckle the driver side front seat belt. 2.Turn the ignition switch to the On position and wait for the seatbelt indicator reminder function to conclude (about six seconds). 3.Unbuckle and buckle the driver side front seat belt three or more times, ending with the belt buckled. 4.Turn the ignition switch to any position except On or Start to toggle the BeltAlert feature from its current setting (from active to inactive, or from inactive to active). A single chime tone will provide an audible confirmation that the programming sequence has been successfully completed Eduardo831 and Cormanthor 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 16, 2015 Report Share Posted January 16, 2015 Well there you go ^^....learn something new every day! Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted January 16, 2015 Report Share Posted January 16, 2015 Is this a do it once thing, or every time you get in the car?? Seems like quite the procedure. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
xcaliber81 Posted January 16, 2015 Report Share Posted January 16, 2015 How do you change it back? Does this disable both seats or does one need to do this on the passenger side as well? Quote Link to comment Share on other sites More sharing options...
bramfrank Posted January 16, 2015 Report Share Posted January 16, 2015 As it says - the procedure toggles the feature. Just do it again to turn it back on. Quote Link to comment Share on other sites More sharing options...
dhh3 Posted January 16, 2015 Report Share Posted January 16, 2015 (edited) Here is an easy fix. I have my seat all the way up, and it is a PITA to plug the seat belt in with the seat raised. I bought a seat belt extender. It looks just like the end attached to the floor. There are two kinds: one with webbing, one without. I bought the one without webbing on ebay. I plugged it in, and the chime has never come on again. And, the seatbelt is a lot easier to buckle. Edited August 16, 2015 by dhh3 priell3 1 Quote Link to comment Share on other sites More sharing options...
DartGTDan Posted March 29, 2015 Report Share Posted March 29, 2015 The following sequence of events must occur within sixty (60) seconds of the ignition switch being placed in the On position in order for the programming to be completed successfully. 1.With the ignition switch in any position except On or Start, buckle the driver side front seat belt. 2.Turn the ignition switch to the On position and wait for the seatbelt indicator reminder function to conclude (about six seconds). 3.Unbuckle and buckle the driver side front seat belt three or more times, ending with the belt buckled. 4.Turn the ignition switch to any position except On or Start to toggle the BeltAlert feature from its current setting (from active to inactive, or from inactive to active). A single chime tone will provide an audible confirmation that the programming sequence has been successfully completed Thanks Milous this procedure worked perfectly! I use my seatbelt until I get into the subdivision, then I take it off (old habit). Quote Link to comment Share on other sites More sharing options...
Woah322 Posted March 30, 2015 Report Share Posted March 30, 2015 (edited) It disables both drivers and passenger, just repeat the process if you want to re activate. After a year an half it finally don't chime. Have no idea how much it bothered me Edited April 15, 2015 by Woah322 Quote Link to comment Share on other sites More sharing options...
Cormanthor Posted August 15, 2015 Report Share Posted August 15, 2015 Thank you Milous! It worked like a charm on my '15 Journey SXT. I have the push button start, so for me I began with the engine off, buckled up, started the car, repeatedly unbuckled/buckled, then cut the car off. When I cut it back on, NO DINGING! Thanks! Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 16, 2015 Report Share Posted August 16, 2015 just tried this on my 14 crossroad it did work but when going under 5mph got message about seatbelt and had to push the back button to see how fast i was going then slowed down again and got the same message again when i was going under 5 mph and then pushed the back button then got the mph back again. i just turned it back to reg settings as we always wear our belts... Quote Link to comment Share on other sites More sharing options...
copperhead33 Posted August 16, 2015 Report Share Posted August 16, 2015 turned mine off the other day also,thank god it was getting annoying Quote Link to comment Share on other sites More sharing options...
bramfrank Posted August 16, 2015 Report Share Posted August 16, 2015 Yes, the display reminder should also be disabled - I said as much when this first came up. Quote Link to comment Share on other sites More sharing options...
nash211 Posted April 16, 2017 Report Share Posted April 16, 2017 On 2015-01-16 at 1:25 AM, Milous said: The following sequence of events must occur within sixty (60) seconds of the ignition switch being placed in the On position in order for the programming to be completed successfully. 1.With the ignition switch in any position except On or Start, buckle the driver side front seat belt. 2.Turn the ignition switch to the On position and wait for the seatbelt indicator reminder function to conclude (about six seconds). 3.Unbuckle and buckle the driver side front seat belt three or more times, ending with the belt buckled. 4.Turn the ignition switch to any position except On or Start to toggle the BeltAlert feature from its current setting (from active to inactive, or from inactive to active). A single chime tone will provide an audible confirmation that the programming sequence has been successfully completed Thanks I will give this a try. Quote Link to comment Share on other sites More sharing options...
Eduardo831 Posted June 12, 2017 Report Share Posted June 12, 2017 On 1/15/2015 at 11:25 PM, Milous said: The following sequence of events must occur within sixty (60) seconds of the ignition switch being placed in the On position in order for the programming to be completed successfully. 1.With the ignition switch in any position except On or Start, buckle the driver side front seat belt. 2.Turn the ignition switch to the On position and wait for the seatbelt indicator reminder function to conclude (about six seconds). 3.Unbuckle and buckle the driver side front seat belt three or more times, ending with the belt buckled. 4.Turn the ignition switch to any position except On or Start to toggle the BeltAlert feature from its current setting (from active to inactive, or from inactive to active). A single chime tone will provide an audible confirmation that the programming sequence has been successfully completed Thanks this worked for me on a 2015 Dodge Journey SXT v6 model. Quote Link to comment Share on other sites More sharing options...
Johnnyh Posted September 3, 2017 Report Share Posted September 3, 2017 Get a seat belt extension and put into the side by the console. Quote Link to comment Share on other sites More sharing options...
Eiza Posted May 8, 2025 Report Share Posted May 8, 2025 Worked a treat thank you !! Been driving me nuts for years !! Quote Link to comment Share on other sites More sharing options...
