are TPS sensors required in winter tires?
lemdog
hey all,
just doing some winter tire/steel wheel shopping and i am wondering if its manditory to get TPS sensors installed into the winter tires.
i know if i dont it "may" throw off my TPMS in the car.
in my previous car i did have a TPMS system with sensors in my summer tires, but my winter tires/wheels did not have the sensors installed and all that happened was the system "chimed" once upon car startup to remind me it couldnt sense the tires and never bothered me again. (until i started the car the next time....... but it was no big deal to me and couldnt care less about TPS in my winters).
just working with a budget and to get these things added is like another $200.00+ on top of tires/wheels. again i couldnt care less if they werent installed in my winters.
so, anyone going without TPS in their winter tires and if so, does the TPMS inside the car remind you once or does it continuously ding in your face?
if it only goes once, im not going to bother paying another $200.00+ on top of a winter package.
any response will be helpful.
thanks!
ok, to save approx $200.00+ i can handle a ding on startup and a light being on. i managed for 8 winters with my previous vehicle (2002 Chrysler 300M Special) with no TPS in my winter set, just a ding on startup with a message in my overhead console "check tire pressure system".
but that went away once my summers went back on and i retrained the system.
i am constantly giving my car a visual every time i am around it and tire level is usually what i check for TPMS or not.
hey all,
thanks!
You can buy original equipment Mopar TPMS on Ebay for anywhere from 50 bucks and up, for a set of 4. Got 4 last May.
Actually, the Canadian model won't bother you at all (no light, nothing) after it first discovers that you have no TPS sensors and you acknowledge it . . . you get the one message and once you clear that it is completely quiet.
Come spring, when you re-install your summer wheels you get one chime and the car figures out which sensor is where and that's the end of it.
I didn't even get the first chime. It shows no info for tire pressure on the EVIC & no lights or dings during the whole winter season.
Edited by Journey_SeXT
I bought some online for my summer 20's, they never even worked! Should have figured $48 online for 4 "brand new" ones wouldn't work! Supposed to be the right frequency to! Went in to see if there was a transmission update, had them try and program the new tps sensors, the scanner didn't even see them. But I've ran all summer without them. You'll just get a few chimes on startup then the light, no big deal.
I hope your dealer didn't charge for his 'sensor check', because the TPMS sensors aren't programmed, they're sensed, at least on the second gen (11 and onward) Journeys.
I bought a sensor offline last year when the first sensor went out took it to get put on they told me it was the wrong one it was supposed to be for my make and model now I don't trust any one who sales them who can I trust to order one offline.
When I purchased my '13 Journey R/T and winter tires with it (Michelin Ice Xi3), I asked about TPMS as I had them on my '08 Caliber SRT4. On my Caliber, I purchased Bridgestone Blizzak's on 18" steel rims, including TPMS sensors. Unfortunately, I got several false positive readings of low tire pressure during the winter [it does get very cold here in winter], resulting in many a stop at a local service station to do an air fill only to find that the air pressure was OK or not low enough to trigger the alarm. So I opted not to install them in my Journey and have had no issue with air pressure last winter or so far this winter. I just make a point to check my tire pressure regularly.
You got it, you just didn't notice.
Hah, got the chime after 15 minutes of driving the other day after switching to winter tires. The light stayed on until the vehicle was turned off and hasn't come back on yet. I never noticed that it came on before as my wife always had the Journey and my short little 5 minute drive probably wasn't long enough to trigger the sensor or better yet, no sensor.
  • 2 months later...
what part of al are you in, i am near huntsville and the forecast is 49 high 22 low with possible rain. of course i don't care i am headed to tunica miss. to the horseshoe casino for couple days of drinking and poker..umh that could get expensive i guess......
