5rebel9 Posted July 5, 2022 Author Report Share Posted July 5, 2022 36 minutes ago, Locosiete said: Ahhhh where's your sense of adventure. What you do is wait until middle of winter when it gets to the worst possible cold imaginable then do it. Not saying i have but that is how you truly enjoy doing it ? My sense of adventure sailed LONG AGO without me after my 5th back surgery! Now I try and do things without stressing the back as much ! Still have the heater core to change on the '11 mainstreet yet.... and am DEFINITELY NOT doing that in blazing heat or freezing cold! Locosiete 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 12, 2022 Author Report Share Posted July 12, 2022 Well it is DEFINITELY the recirculation door actuator. Got it out pretty easily, chipped gear teeth AND a broken post for one of the gears inside the actuator. Recirc DOOR movement is fine.so the new one will go in Wed. afternoon. EVERYTHING else about the new to us" '14 Journey is doing just FINE. Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 12, 2022 Report Share Posted July 12, 2022 (edited) 54 minutes ago, 5rebel9 said: Well it is DEFINITELY the recirculation door actuator. Got it out pretty easily, chipped gear teeth AND a broken post for one of the gears inside the actuator. Recirc DOOR movement is fine.so the new one will go in Wed. afternoon. EVERYTHING else about the new to us" '14 Journey is doing just FINE. where is the recirculation door at? i know the location of the drivers and 2 on the passenger side. just looked on you tube, guess it is the one on the left side of the cabin filter Edited July 13, 2022 by 2late4u Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 13, 2022 Author Report Share Posted July 13, 2022 24 minutes ago, 2late4u said: where is the recirculation door at? i know the location of the drivers and 2 on the passenger side. just looked on you tube, guess it is the one on the left side of the cabin filter Drop the glovebox door and it's below the "drawstring" assembly for the the glovebox door. The actuator for recirculation air is right the on the end of the HVAC box. Found that dropping down the interior fuse panel give more working room for the 2 screws. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 13, 2022 Author Report Share Posted July 13, 2022 11 minutes ago, Locosiete said: It's easy to replace if you have rubber arms or can balance on your head easily lol I don't contort around well anymore but used to working in "tight confines". I just knelt outside the pass. door and got my arms and head inside the car to get at it. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 13, 2022 Author Report Share Posted July 13, 2022 (edited) 21 hours ago, 5rebel9 said: I don't contort around well anymore but used to working in "tight confines". I just knelt outside the pass. door and got my arms and head inside the car to get at it. Had to wait till after supper to install the actuator due to wife getting home late from work. GOSH, it was even easier to install when I moved the pass. seat backfully! I used a little carpenters trick with the screws of a dab of bar soap on the threads and could finger tighten them in(along with a bit of masking tape holding the screw to the #2 phillips long1.5" shank bit so they didn't fall off). then tightened with a 1/4" wrench on the "bit". Took me all of 15 minutes start to finish! Tested and watched recirc door movement and at actuator before putting glovebox back in too in that short time! ALL IS GOOD NOW with no other "glitches" showing up! Now to get the remote start kit ordered and installed! Edited July 13, 2022 by 5rebel9 2late4u and Locosiete 2 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 14, 2022 Author Report Share Posted July 14, 2022 (edited) 6 hours ago, Locosiete said: I mean sure you can do it the easy way... but where is the fun in that ? ? ? Guess you can still say that I'm still "NEW TO THE JOURNEY" as both of ours are NOT my rides, they are for my wife and son. 99.5% of my traveling is done in MY Buick Lucerne! I had not realized that the wife had positioned the pass. seat to match where she keeps HER drivers seat when I removed the old actuator! A lot of wire harnesses near the actuator that the removal step made me think about an easier way to get back together without dropping screws or tools and having to go "fishing" for them! 0 Edited July 14, 2022 by 5rebel9 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted August 29, 2022 Author Report Share Posted August 29, 2022 Well it's the last week before the "unofficial" end of summer(Labor day) . Time to start looking into 4 rims and new SNOW TIRES for the '14 ! The '11 is all set for it's winter "shoes" The '14 has had 2,500 miles put on it so far and is running GREAT. Just have to secure the both front seat side plastic panels that hold the controls AND get busy about putting in a remote start system (which I have not even looked for yet). Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted August 29, 2022 Author Report Share Posted August 29, 2022 4 hours ago, Locosiete said: Glad to know mine are not the only ones that keep breaking. Bad design so every time you get in or out it puts pressure on them amd they break Yeah, the'11 is the same way, but that's my son's problem to resolve on his own ,,, AFTER I figure out a fix for the wife's '14 and he can then COPY the "fix" to his! Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 29, 2022 Report Share Posted August 29, 2022 58 minutes ago, 5rebel9 said: Yeah, the'11 is the same way, but that's my son's problem to resolve on his own ,,, AFTER I figure out a fix for the wife's '14 and he can then COPY the "fix" to his! both my 2011 and then my 2014 on passenger side the plastic side cover would break,,,simple solution for me was a small black screw, simply hold the cover in place and then drill a small hole then run the screw in to it and have never had any more problems, hardly even see the screw after a while Locosiete 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 29, 2022 Report Share Posted August 29, 2022 2 hours ago, Locosiete said: Can you share a picture actually i tried to upload the picture but i am techannlly chanaged...LOL but if looking at the seat side cover you have 2 plastic clips that hold it on and it has been the front one that tears up on my passenger side so i just get the rear clip hooked on and then place the cover where it looks to fit on the front and then try to push it down just a hair and then drill towards the front about 2-3 inches back and about the same from the top you will either hit the metal or the plastic behind the cover then install the screw . on my 2014 i had katzkin leather company install a seat warmer as my journey didnt come with them and when he installed the rocker switch for the heater on the side he didnt get it in the right place so the rocker switch bulges out a bit, but i didnt noticed in time to have them fix it proper so i just added another screw by the switch as well...when my daughter comes over ill try and get her to download the picture, but you should be able to do it Locosiete 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted August 30, 2022 Author Report Share Posted August 30, 2022 (edited) 10 minutes ago, 2late4u said: actually i tried to upload the picture but i am techannlly chanaged...LOL but if looking at the seat side cover you have 2 plastic clips that hold it on and it has been the front one that tears up on my passenger side so i just get the rear clip hooked on and then place the cover where it looks to fit on the front and then try to push it down just a hair and then drill towards the front about 2-3 inches back and about the same from the top you will either hit the metal or the plastic behind the cover then install the screw . on my 2014 i had katzkin leather company install a seat warmer as my journey didnt come with them and when he installed the rocker switch for the heater on the side he didnt get it in the right place so the rocker switch bulges out a bit, but i didnt noticed in time to have them fix it proper so i just added another screw by the switch as well...when my daughter comes over ill try and get her to download the picture, but you should be able to do it Same boat I am in with you 2late4u ! I'm good with automotive and figuring out THEIR electrical "glitches" , BUT with "smart phones, Picture posting and "linking" things, I'm a complete DUNCE! Edited August 30, 2022 by 5rebel9 2late4u 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted September 25 Author Report Share Posted September 25 I know this is in the Owners impressions forum...BUT It is coming time to close the book on old red (2011 mainstreet). The last posting I made somewhere in one of my many postings of his "disposition" was to give him up to scrap, due to lack of time to find/fix coolant leak and overall body condition. THE GOOD NEWS The coolant loss was a ruptured oil filter /cooler assembly, which I did replace with an aluminium unit along with the aluminum T-stat and a new fan resistor. The engine is FINE with no damage from the limp home with it when it blew. Seeing as I had gone that far with it, I then looked over the damage from the initial problem of my son glancing a deer that tore the bumper cover off and broke some plastic wheel arch panels and side cover attachment brackets. I was able to acquire all needed pieces from my friend AND reuse the bumper cover. SO the car is all back together !!! THE SAD NEWS This car was our first DJ, and was a REAL LEARNING EXPERIENCE with all the troubles we overcame with it and had proven to be a reliable ride for my son. BUT now We are putting it up for sale at an almost "give away" price considering the cost of parts to fix the cooling system(which I did all the labor). It will need new pads and rotors all around due to sitting parked for almost 8 months and the WET year we had this year. I have one family coming Sat. to look at the car for their son as a first car for him( yes he is going to be here also). I hope it goes well! larryl, Armando G and 2late4u 3 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted September 26 Author Report Share Posted September 26 The FINAL SAY GOODBYE TO "OLD RED"! The family came at noon today with the young man who will be driving "old red". When he finishes high school this June he is going into the MARINE CORPS, sadly to me as INFANTRY(a GRUNT) as I was an "airedale aviation jet engine MOS. So I came down a little to $750 and the deal is DONE, which ALL were VERY PLEASED. I will miss "old red" as I did form an emotional attachment to him from all the work I had put into him over the last 6 years. My friend will be doing the brake work for them, so he although not ending up with the car for parts, will make a little money instead...again ALL parties HAPPY! Old Red will leave my driveway for the final time mid week once paperwork is completed. Armando G, 2late4u and Locosiete 1 1 1 Quote Link to comment Share on other sites More sharing options...
Armando G Posted October 20 Report Share Posted October 20 This had been an interesting thread throughout the years. Is this what you call full circle? I'm glad the DJ is going to be driven and hopefully will make a new owner happy. These emotional attachments to our cars is tough, as I am getting close to moving on myself. 🫤 5rebel9 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted October 20 Author Report Share Posted October 20 12 hours ago, Armando G said: This had been an interesting thread throughout the years. Is this what you call full circle? I'm glad the DJ is going to be driven and hopefully will make a new owner happy. These emotional attachments to our cars is tough, as I am getting close to moving on myself. 🫤 Yes, it has gone full circle. I don't like having a machine beat me mechanically, NY RUST is what makes me have to give them up. We still have the '13 RT the '13 4 banger and the '17 crossroad, along with the '14 Caravan wheelchair van and my Buick. Yes, I've heard good things of the 4runner model, nice choice and I hope it serves you well! Locosiete and Armando G 1 1 Quote Link to comment Share on other sites More sharing options...
Nicholas Seward Posted November 5 Report Share Posted November 5 Good to hear the trip went smoothly and your son is now a confirmed DJ owner. On the cat efficiency code: at 181k on a '11 that sat a lot, worn O2 sensors is a reasonable bet before condemning the cat itself. As the other poster suggested, a Techron treatment and a couple of fill-ups is a cheap way to see if it clears. If MPG and drivability stay fine and Florida inspection doesn't flag it, monitoring is fair. I'd just log when it sets so you can spot a pattern with fuel brands. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted November 5 Author Report Share Posted November 5 6 hours ago, Nicholas Seward said: Good to hear the trip went smoothly and your son is now a confirmed DJ owner. On the cat efficiency code: at 181k on a '11 that sat a lot, worn O2 sensors is a reasonable bet before condemning the cat itself. As the other poster suggested, a Techron treatment and a couple of fill-ups is a cheap way to see if it clears. If MPG and drivability stay fine and Florida inspection doesn't flag it, monitoring is fair. I'd just log when it sets so you can spot a pattern with fuel brands. New O2 sensors took care of that problem a LONG TIME ago. He is now driving a '13 4cyl model and still wishing for better fuel economy like his first car, an '04 NEON which gave him 30mpg. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Nicholas Seward Posted November 6 Report Share Posted November 6 Glad the trip went smoothly and your son got home safe. On the cat efficiency code, I agree with monitoring it rather than throwing parts at it right away, especially at 181k with an unknown maintenance history. An aging O2 sensor behind the cat can mimic a tired converter, so watching the downstream voltage behavior would tell you more than guessing. If driveability and the 24 mpg hold steady, letting it ride makes sense unless Florida inspection forces the issue. Quote Link to comment Share on other sites More sharing options...
