nnngn_zero Posted February 9, 2020 Report Share Posted February 9, 2020 My delightful 2015 SXT now has 95,000 on the odo. During a routine oil change, when I removed the oil filter there was an unusual piece of plastic caught in the "nipple thing" in the bottom of the oil filter. It appears to have come from the filter cap where the piece slides inside the filter. Now the oil cap rattles when it is shaken and I can see there is a loose spring in the bottom of the cap that I do not remember being loose. I am going to replace the cap eventually, but it will have to be ordered. In the meantime I am going to put the cap back on in its current condition. I assume this part is related to the oil bypass?? How detrimental would it be to drive without it? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 9, 2020 Report Share Posted February 9, 2020 i do all my own oil changes on my 2014 so are you saying part of the oil cap has a small piece of plastic broke off from it? as the filter nipple faces downward there was some plastic piece caught in the nipple? hmm i dont see how the cap could rattle as it screws on fairly tight, as long as it doesn't leak,and you dont have no problems with the oil bypass valve not working you would be okay for a while i guess... some bad news for you iv read on here from some other post that just the cap cannot be ordered without the whole oil assy cooler you might would find one at a junk yard or maybe e bay i guess. good luck and please report back on what ever you do or find out for others that might have this problem Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 9, 2020 Report Share Posted February 9, 2020 just found the cap on amazon prob cheaper than the dealership Mopar Genuine 68191350AA Engine Oil Filter Housing Cap $15.64 Quote Link to comment Share on other sites More sharing options...
nnngn_zero Posted February 9, 2020 Author Report Share Posted February 9, 2020 Yes, the cap can be found from auto parts stores for +/- $20 However none of them have one in stock. Picture of the piece that separated from (I assume) the oil filter cap attached. Now when I look on the inside of the oil filter cap, I can see a loose spring inside the housing that I believe this piece was connected to. The cap rattled when shaken before re-installation due to the loose spring. It did not do this before. Quote Link to comment Share on other sites More sharing options...
Hankster Posted February 9, 2020 Report Share Posted February 9, 2020 I had this happen on the 3.6 in my van. I also noticed that the spring was loose in the cap. Check for this by shaking the cap, if it rattles. Replace it. Hank Quote Link to comment Share on other sites More sharing options...
yyz Posted February 10, 2020 Report Share Posted February 10, 2020 (edited) Watch this it's probably what you need for the older 3.6l the part is listed this is the guy that got them to make the bypass available without replacing the entire assembly Edited February 10, 2020 by yyz agm2112 and jkeaton 1 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted February 10, 2020 Report Share Posted February 10, 2020 Nice link YYZ lots of info there. Sooo it seems like the check valve that is broken, forces the oil through the filter. Driving it as is means the oil can bypass being filtered, short term not that big a deal IMO. Early cars didn’t even have oil filters until approx the early 1950’s and the oil quality was also crap. With the mopar part number some else posted, you should be able to track down part. Rockauto lists a dorman and mopar oil filter cover, both in stock for between $11- $17 cdn pesos. Rockauto really rocks for parts IMO, cheap shipping and quick delivery even across border. Good luck. https://www.rockauto.com/en/catalog/dodge,2015,journey,3.6l+v6,3309784,engine,oil+filter+cover,5561 Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 10, 2020 Report Share Posted February 10, 2020 9 hours ago, yyz said: Watch this it's probably what you need for the older 3.6l the part is listed this is the guy that got them to make the bypass available without replacing the entire assembly as he should notice this not the oil cooler he has in his 2015, to be honest i just changed my oil in my 2014 and i cant remember what is in the cap that could have broke off like what he is showing in his hand that would make the cap rattle,as the new filter with the nipple goes in facing downward in the newer journey,and actually dorman does make a kit to fix the old style by pass after it is broken. Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 10, 2020 Report Share Posted February 10, 2020 (edited) yep Edited February 10, 2020 by 2late4u spelling Quote Link to comment Share on other sites More sharing options...
John/Horace Posted February 10, 2020 Report Share Posted February 10, 2020 The newer style lid like in my picture has a small plastic piece held in place by two tabs. The small plastic piece looks identical to what he is holding in his hand. I had to replace my leaking oil cooler last year, the pic is the newer style cap from my 2014. I’m guessing the plastic sometimes gets britttle with age and the constant heat. I think this piece seals opening in top of filter, part of bypass design. Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 10, 2020 Report Share Posted February 10, 2020 good to know, as many times iv changed my oil ( 100 k) iv never bothered to look inside the cap Quote Link to comment Share on other sites More sharing options...
Jimmy12 Posted May 4, 2025 Report Share Posted May 4, 2025 On 2/10/2020 at 10:21 AM, John/Horace said: The newer style lid like in my picture has a small plastic piece held in place by two tabs. The small plastic piece looks identical to what he is holding in his hand. I had to replace my leaking oil cooler last year, the pic is the newer style cap from my 2014. I’m guessing the plastic sometimes gets britttle with age and the constant heat. I think this piece seals opening in top of filter, part of bypass design. In my case, I stupidly left the unscrewed oil filter cap on my bumper, it fell off and the spring valve popped out. I got it to go back in but it didn’t clip in. I’m currently using it as is. What’s the point of this piece? Quote Link to comment Share on other sites More sharing options...
yyz Posted May 5, 2025 Report Share Posted May 5, 2025 20 hours ago, Jimmy12 said: In my case, I stupidly left the unscrewed oil filter cap on my bumper, it fell off and the spring valve popped out. I got it to go back in but it didn’t clip in. I’m currently using it as is. What’s the point of this piece? it's the oil filter bypass https://www.dormanproducts.com/p-85925-917-992.aspx Quote Link to comment Share on other sites More sharing options...
