Mike Koppler Posted October 23, 2015 Report Share Posted October 23, 2015 Hi I have a 2013 Dodge journey r/t with a little over 35k miles and I have two questions. First question, do these things always run really hot? My temperature gauge is normally half way and not overheating, but this thing puts out so much heat from the engine. Second question, I read about the whole engine ticking at cold start-up, but what about after its already warmed up, should it still continue? dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted October 23, 2015 Report Share Posted October 23, 2015 Mine doesn't, but then I only have around 8500 miles on it. It is still "breaking in". I'll bet that the beauty cover traps heat, unless it is designed to control the flow of air under it. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted October 23, 2015 Report Share Posted October 23, 2015 (edited) No issues with temps or ticking for me. What are you comparing "really hot" to? If it's not overheating and the gauge is in the normal range then it is not "really hot". You should check your coolant level though or have the system flushed if you think there is a problem. Edited October 23, 2015 by jkeaton dhh3 1 Quote Link to comment Share on other sites More sharing options...
silenze Posted October 23, 2015 Report Share Posted October 23, 2015 On mine The display in the driver information center always reads halfway even when cold. Just the temperature changes dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 23, 2015 Report Share Posted October 23, 2015 Engine heat is a little higher in newer vehicles with the tight engine compartments, engine covers, insulation etc... I wouldn't worry about it. And yes, the gauge midway is about correct. dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Mauricio Pelissari Posted October 23, 2015 Report Share Posted October 23, 2015 Well this is normally for me, no ticking on my though... but on the temperature you can feel the heat come from under nit and specially from the side of the coolant recipient... but always at the correct point.... this type of car operates a significant high temp... compare to others... dhh3 1 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted October 23, 2015 Official Dodge Support Report Share Posted October 23, 2015 Mike, It sounds like your vehicle should still be under warranty, so I'd recommend a trip to the dealership before hitting that 36,000 mile mark to have your DJ diagnosed. As others have said above, this could very well be normal, but it still may be a good idea to have it checked out at a dealership. casey sohc, jkeaton and dhh3 3 Quote Link to comment Share on other sites More sharing options...
Mauricio Pelissari Posted October 23, 2015 Report Share Posted October 23, 2015 From the service manual it self: "The water pump draws coolant from the radiator and delivers it to the engine block. The coolant travels through the engine block into the cylinder head. Coolant exits the engine at the thermostat. If the coolant temperature is less than 87°C (189°F) the thermostat directs all of the coolant back to the water pump. If the coolant temperature is between 87°C (189°F) and 102°C (216°F) the thermostat is in the mix mode and directs the coolant to the radiator and the water pump. If the coolant is greater than 102°C (216°F), the thermostat directs all of the coolant to the radiator." Also a good indication of high temps is excessive use of the fan on high speed frequently, starting and stopping... RADIATOR FAN OPERATION - 3.5L ENGINE Radiator Fan Control A/C Pressure A/C Off Low High Fan On: 102°C (215°F) 104°C (219°F) Fan Off: 98°C (208°F) 100°C (212°F) A/C On Low High Low High Fan On: 102°C (215°F) 104°C (219°F) 1,526 Kpa (221 psi) 1,932 Kpa (280 psi) Fan Off: 98°C (208°F) 100°C (212°F) 1,246 Kpa (180 psi) 1,666 Kpa (224 psi) if your indication is at the middle is normally and also you could say that close to 100 degrees Celsius is normal. to monitor this value very close you would need to plug one of those OBD2 to monitor. But as DodgeCares above says if you have any doubts take it to a dealer especially if it is under warranty. jkeaton, StormGrayBlackTop13 and dhh3 3 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 26, 2015 Report Share Posted October 26, 2015 From the service manual it self: "The water pump draws coolant from the radiator and delivers it to the engine block. The coolant travels through the engine block into the cylinder head. Coolant exits the engine at the thermostat. If the coolant temperature is less than 87°C (189°F) the thermostat directs all of the coolant back to the water pump. If the coolant temperature is between 87°C (189°F) and 102°C (216°F) the thermostat is in the mix mode and directs the coolant to the radiator and the water pump. If the coolant is greater than 102°C (216°F), the thermostat directs all of the coolant to the radiator." Also a good indication of high temps is excessive use of the fan on high speed frequently, starting and stopping... RADIATOR FAN OPERATION - 3.5L ENGINE Radiator Fan Control A/C Pressure A/C Off Low High Fan On: 102°C (215°F) 104°C (219°F) Fan Off: 98°C (208°F) 100°C (212°F) A/C On Low High Low High Fan On: 102°C (215°F) 104°C (219°F) 1,526 Kpa (221 psi) 1,932 Kpa (280 psi) Fan Off: 98°C (208°F) 100°C (212°F) 1,246 Kpa (180 psi) 1,666 Kpa (224 psi) if your indication is at the middle is normally and also you could say that close to 100 degrees Celsius is normal. to monitor this value very close you would need to plug one of those OBD2 to monitor. But as DodgeCares above says if you have any doubts take it to a dealer especially if it is under warranty. He has a 2013... I'm pretty sure you can monitor most, if not all, of the important temperatures from the EVIC display in the dash... dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted October 26, 2015 Report Share Posted October 26, 2015 Wonder if we will ever know..... dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted October 26, 2015 Report Share Posted October 26, 2015 My "real" temp guage always reads 3/8. Addicted to Dodge 1 Quote Link to comment Share on other sites More sharing options...
Addicted to Dodge Posted October 26, 2015 Report Share Posted October 26, 2015 Emmissions is another reason for the higher engine temps. All manufactures try to reduce emmissions by running higher temps from what we are use to. A hot engine is a cleaner, less pollutant engine. Its been a common question on Ramforumz. Folks with 3.6 Ram have been complaining of temps over 230 degrees. Its normal and not anything to worry about. dhh3 and Lobitz68 2 Quote Link to comment Share on other sites More sharing options...
