Brig Posted September 6, 2015 Report Share Posted September 6, 2015 Hi, I pulled out a front seat headrest because I bought seat covers for my Dodge Journey 2010, unfortunately I didn't realize there is a wire for the AHR and I pulled it out, the connector came loose. Now the airbag light is on and I am not sure what to do. I was reading here it could cause the airbag to go off and this makes me very nervous. Can I re-connect the wire without problems? Can somebody please advise. Thanks, Bri dhh3 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted September 6, 2015 Report Share Posted September 6, 2015 Welcome to the forum. Disconnect the DJs battery at the negative jumper point before you do anything electrical on these vehicles. It may be as simple as reconnecting/soldering the wires back to original and reconnecting battery/driving X miles or having the stored code reset. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Brig Posted September 6, 2015 Author Report Share Posted September 6, 2015 Thank you for your answer. Is there any risk the airbag will go off if I drive, or is it just a warning that the airbag won't function? Is it hard to disconnect the negative jumper? dhh3 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted September 6, 2015 Report Share Posted September 6, 2015 I don't believe it will go off because those connections are only for firing and not triggering the actual deployment. The negative jumper point under the hood is readily accessible and you only need the appropriate tools. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Brig Posted September 6, 2015 Author Report Share Posted September 6, 2015 I read somewhere you have to turn the wheel, others were saying the wheel needs to be removed to get access to disconnect the battery, do you have any idea? dhh3 1 Quote Link to comment Share on other sites More sharing options...
Brig Posted September 6, 2015 Author Report Share Posted September 6, 2015 Do you think it's safe to drive to the garage and have them reconnect the wire? dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted September 6, 2015 Report Share Posted September 6, 2015 The battery itself is located just in front of the driver's side front wheel. There are remote disconnects on the front of the driver's side wheel well under the hood. Disconnect the negative first, and wait a while for all the diodes to discharge. Then you should be able to hook it back together. Quote Link to comment Share on other sites More sharing options...
Brig Posted September 6, 2015 Author Report Share Posted September 6, 2015 Do you know if the seatbelt light will go off after I do this? dhh3 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted September 6, 2015 Report Share Posted September 6, 2015 I honestly don't know what the wiring convention is for seat belt but it is integrated with the seat weight sensing and seat belt home position. Check the plugs/connections under the seat. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Brig Posted September 7, 2015 Author Report Share Posted September 7, 2015 Sorry I meant to say airbag light ... dhh3 1 Quote Link to comment Share on other sites More sharing options...
Brig Posted September 7, 2015 Author Report Share Posted September 7, 2015 Would anybody know if it's safe to drive to the garage with the headrest pulled out and airbag light on? Or could this possibly trigger the airbag to go off? dhh3 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted September 7, 2015 Report Share Posted September 7, 2015 As I said "the wiring isn't the trigger for air actuation those devices are located elsewhere." It will be safe to drive to dealer with indicators lit. dhh3 1 Quote Link to comment Share on other sites More sharing options...
silenze Posted September 7, 2015 Report Share Posted September 7, 2015 I think if the airbag light is on the whole system will not work. So dont get in a crash Quote Link to comment Share on other sites More sharing options...
OhareFred Posted September 8, 2015 Report Share Posted September 8, 2015 If your airbag light is on, you have no airbags. There are airbags for the rear seats in the back of the front seats. This needs to go to the dealer or someone VERY FAMILIAR with airbag systems. Quote Link to comment Share on other sites More sharing options...
Brig Posted September 9, 2015 Author Report Share Posted September 9, 2015 Thank you all for the help, I went to the dealer today and they fixed it, airbag light is off again, the connector in the seat is hard to reach and would not come apart easily and even my regular garage would not touch it. Nicole and jkeaton 1 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted September 9, 2015 Report Share Posted September 9, 2015 Thanks for reporting back. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Nicole Posted January 9, 2023 Report Share Posted January 9, 2023 (edited) @Brig how much did it end up costing you if you don't mind me asking? Same thing happened with my daughter's Journey last night. I just got quoted $160 just to look at it. He said it sounds expensive.... Edited January 9, 2023 by Nicole Quote Link to comment Share on other sites More sharing options...
yyz Posted January 9, 2023 Report Share Posted January 9, 2023 8 hours ago, Nicole said: @Brig how much did it end up costing you if you don't mind me asking? Same thing happened with my daughter's Journey last night. I just got quoted $160 just to look at it. He said it sounds expensive.... That post was from 2015 don't expect a reply from them. Quote Link to comment Share on other sites More sharing options...
Brig Posted January 9, 2023 Author Report Share Posted January 9, 2023 If my memory serves me well, I think it was about 150/200 dollar John/Horace 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted January 10, 2023 Report Share Posted January 10, 2023 If the wires are clearly marked and you know polarity. Unhook battery for 10 mins to discharge all stored power. Don’t want to accidentally trigger airbags. Then solder and heat shrink broken wires. Hook up battery again. May have to clear codes to get rid of light, although 20 start cycles might clear it. Quote Link to comment Share on other sites More sharing options...
Ihor Posted October 5, 2025 Report Share Posted October 5, 2025 Hi, pls advise, I had same situation as Brig. I ripped the wires out from the yellow plastic connector out when I pulled out headrest from the seat... And now I don't know (don't see) the polarity of wires to restore right connection... Can I connect wires at random till red light go out? And how this yellow connector is correctly called? What type? I afraid I broke the connector... Thank you! Quote Link to comment Share on other sites More sharing options...
