Tacktack Posted December 15, 2025 Report Share Posted December 15, 2025 My Journey 2011 has a hiccup. I hear a noise, like tack tack tack (~10 tacks) ... apparently from under the dash on the passenger side. I hear it clearly when I am inside the car (while starting or stopping the engine), but I also hear it randomly outside the vehicle when the car is simply parked. It has been so for a few months. It slowly drains the battery. Outside temperature now is below the freezing point and a fully charged battery is needed. Rear AC is disabled on the front screen. Is this a common problem? Should I "show" a recording? Is it possible? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted December 16, 2025 Report Share Posted December 16, 2025 Yes, it is a fairly common problem. It is most likely a broken RECIRCULATION door ACTUATOR causing the clicking sound. MANY You Tube videos on how to determine and replace the part., and not too difficult a task to perform. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Tacktack Posted December 16, 2025 Author Report Share Posted December 16, 2025 Thanks a lot. With your tip, I am on my way. Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 16, 2025 Report Share Posted December 16, 2025 yes the blend doors will make that noise during operation of the unit and after you shut the car off for a minute or two while it goes into resting position,,,but it shouldn't do it at random times while it drains your battery,sounds like you also have an other problem that is causing it to activate or short out,,as far as the rear ac being disabled have no idea on that problem John/Horace 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted December 18, 2025 Report Share Posted December 18, 2025 (edited) Yeah blender door actuator is a wear item. But not likely draining battery. Most cars to vent interior when car is shut off cycle actuator to not accumulate condensation on windows. After about 2 mins there should be no cycling, vent back in closed position. Lower glove box door, remove HVAC filter door and paper filter. Blend door is now fully visible for operation. You are probably having issues with fogged up windows if your actuator is sticking. If you decide to change it, you need to remove the power fuse for the actuator before changing part. Other wise it will end up out of position when harness plug is removed (drops constant power). Or install part using bi directional scanner calibration procedure, which does it for you. Most common parasitic drain on Journey is the Bluetooth module messing up (if you have the option). Pull fuse labeled hfm (hands free module) for a few days and see if drain stops. Fuse located in passenger front kick panel box. There are companies that rebuild the Bluetooth modules to fix problem. New they are crazy expensive. Glove box light staying on, stuff charging in car cig ports, bad alternator diodes other possibilities. Edited December 18, 2025 by John/Horace 2late4u 1 Quote Link to comment Share on other sites More sharing options...
TomKat1988 Posted August 21 Report Share Posted August 21 How do you fix the noise from the actuator or is it a constant thing that can’t be fixed? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 21 Report Share Posted August 21 Turn the radio up, wear ear plugs, etc. larryl 1 Quote Link to comment Share on other sites More sharing options...
TomKat1988 Posted August 21 Report Share Posted August 21 Just now, jkeaton said: Turn the radio up, wear ear plugs, etc. not helping jkeaton 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 21 Report Share Posted August 21 46 minutes ago, TomKat1988 said: not helping LOL,,,,In case you didn't read the above poster just Google on you tube for 2013 JOURNEY blend doors replacement, I would use an OEM blend door actuator yes more expensive than the cheap chinese junk but will last longer, some folks have reported problems that the new one isn't resetting correctly so watch all the you tube videos and also check in our forum for a lot of info on how to do it under the heading Climate Control jkeaton and John/Horace 2 Quote Link to comment Share on other sites More sharing options...
