edvoyager695 Posted February 24, 2023 Report Share Posted February 24, 2023 Hello there! I'll start by saying I know this is a fairly well documented topic, but I have searched this and other forums and other places and haven't found what I am looking for (posibly just not searching the right stuff?). Anyway, I have a 2013 DJ SXT that technically did not have remote start. I have been successful in programming a new key with the remote start option, enabled the remote start in the computer, and it almost works. My last hurdle is the hood ajar switch. I get the horn honk, but then the 'Remote stat aborted, hood ajar' message when I try and use the remote start. I can find the connectors and replacement hood latches with the thing all over the internet, buy my question is: does the wiring for this switch already exist on the car or not? And if not, is there a diagram that shows where I need to start to connect a switch to the proper controlling module? I have looked all around the wiring on the front of the vehicle and did not see anything that looked like the correct connector for this switch. If I can find out where it terminates normally I could add one in, but that information has not been easy to find. I was hoping to avoid paying for wiring diagrams for this one thing (plus I kinda suck at reading them tbh), so here I am. Thanks in advance for any advice or input on this! Quote Link to comment Share on other sites More sharing options...
tsteves5 Posted February 24, 2023 Report Share Posted February 24, 2023 According to the online service manual for my 2011, the connector for the hood switch is a 2-pin oval connector located on the lighting wiring harness by the passenger-side headlamp. I don't know if it's the same on a 2013. It looks like it connects to the Body Control Module, so you might be able to run wires from that module if your current harness does not have them. I would suggest getting a AllDataDIY subscription so you can check to make sure the wiring is the same on your 2013. Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 24, 2023 Report Share Posted February 24, 2023 check rock auto for cheapest price found this on ebay,,,,,,,,you will also need the wiring to attach to the wiring harness,,,,,i believe it goes on the front passenger side just behind the light,,,,,your best bet is to go to a dodge dealership to get more info and price on the part and THEY will be able to give the exact location of the installed part and what other parts you will need as well...please report back on what you find For 2009-2018 Dodge Journey Hood Ajar Indicator Switch SMP 33696KV 2010 2011 (For: 2013 Dodge Journey) Opens in a new window or tab Brand New $34.34 autopartsgeek (227,636) 95.9% Buy It Now Free shipping Quote Link to comment Share on other sites More sharing options...
edvoyager695 Posted February 25, 2023 Author Report Share Posted February 25, 2023 Thanks for the replies! I did have the purple connector behind the passenger headlamp so after getting the connector and latch I'm hoping to be set from what I can see. Quote Link to comment Share on other sites More sharing options...
Dodgems Posted February 25, 2023 Report Share Posted February 25, 2023 Can you keep us updated on progress? I have an aftermarket remote start module from a 16 I was going to install but if you get the oem working with new keys and hood switch I will pursue that route instead. Quote Link to comment Share on other sites More sharing options...
edvoyager695 Posted February 25, 2023 Author Report Share Posted February 25, 2023 2 hours ago, Dodgems said: Can you keep us updated on progress? I have an aftermarket remote start module from a 16 I was going to install but if you get the oem working with new keys and hood switch I will pursue that route instead. Yep, I will post updates as I get things accomplished. I am ordering the hood switch now and need to see if the switch bracket is already in there or find one of those as well. But once I get that in I'll update on the results. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted February 25, 2023 Report Share Posted February 25, 2023 (edited) Welcome to the site. This is a 2014 Journey picture. No bracket, molded plastic , so you probably just have an open hole. Edited February 25, 2023 by John/Horace Quote Link to comment Share on other sites More sharing options...
edvoyager695 Posted February 25, 2023 Author Report Share Posted February 25, 2023 37 minutes ago, John/Horace said: Welcome to the site. This is a 2014 Journey picture. No bracket, molded plastic , so you probably just have an open hole. Awesome! I had looked at some pictures online and couldn't tell for sure and hadn't gone out to check, so this is perfect. Once the switch comes in I'll slide it in place and cross my fingers. Quote Link to comment Share on other sites More sharing options...
Dodgems Posted February 25, 2023 Report Share Posted February 25, 2023 I ordered a remote start key fob and resistor today. I may have time tomorrow to fiddle with ours if they actually arrive tomorrow. I will update here as well once I get to it. I did not search but glanced under the hood this morning before she left for work and did not see the harness. I found an install manual but half of it is in another language. It shows the wiring is present but taped up near right headlight. I will look again tonight if she gets home before dark. The oem kit includes a new antenna. I wonder why. Maybe to increase range? If the fob talks to the car that should be all we need. I wonder if the new rf hub has the additional antenna port but the oem non remote start doesn't? Or is it just a bunch of parts that are not really needed but justify the cost and install time? The description says hood ajar harness but the pics I found and the install manual do not show adding a harness. It just says "Locate existing harness and cut away retaining tape" Quote Link to comment Share on other sites More sharing options...
Dodgems Posted February 27, 2023 Report Share Posted February 27, 2023 Remote Start Works!!!!! The hood switch harness is attached to the right headlight harness. Mine had the cloth like tape covering it. I installed a 1k ohm resistor. Programmed a new remote with the remote start button. Used Alfa to enable remote start and hood ajar switch present. Reset the rf hub using Alfa. And....It would not work. I could get 1 beep from the horn but that was it. Didn't matter how may times I hit the start button on the remote. It would beep on the 1st press and that's all. Letting it sit for 10 minutes did not help. So I drove around for 10 minutes and shut it off. It works! Cost a new remote from Amazon. $35 and the resistor was maybe 10 cents. I will get the hood ajar switch now that I know it works. Wife is very happy!! edvoyager695 1 Quote Link to comment Share on other sites More sharing options...
edvoyager695 Posted February 27, 2023 Author Report Share Posted February 27, 2023 2 hours ago, Dodgems said: Remote Start Works!!!!! The hood switch harness is attached to the right headlight harness. Mine had the cloth like tape covering it. I installed a 1k ohm resistor. Programmed a new remote with the remote start button. Used Alfa to enable remote start and hood ajar switch present. Reset the rf hub using Alfa. And....It would not work. I could get 1 beep from the horn but that was it. Didn't matter how may times I hit the start button on the remote. It would beep on the 1st press and that's all. Letting it sit for 10 minutes did not help. So I drove around for 10 minutes and shut it off. It works! Cost a new remote from Amazon. $35 and the resistor was maybe 10 cents. I will get the hood ajar switch now that I know it works. Wife is very happy!! Sweet, glad to hear it worked out! I went backwards and enabled the feature first with AlfaOBD and then programmed a key the next day. Once my switch comes in (looking like Tuesday) I am hoping my results will be as good as yours! Dodgems 1 Quote Link to comment Share on other sites More sharing options...
Dodgems Posted February 27, 2023 Report Share Posted February 27, 2023 At first I could not get the key to program. I had to replace the battery in the new remote then it worked. When first using the lock and unlock buttons it was hit or miss for a few minutes. I was starting to get worried the remote was bad. After the short drive it has worked fine. The panic button does not work but it doesn't work on 1 of the factory remotes as well. Quote Link to comment Share on other sites More sharing options...
AOXOMOXOA Posted February 28, 2023 Report Share Posted February 28, 2023 On 2/24/2023 at 11:26 AM, edvoyager695 said: Hello there! I'll start by saying I know this is a fairly well documented topic, but I have searched this and other forums and other places and haven't found what I am looking for (posibly just not searching the right stuff?). Anyway, I have a 2013 DJ SXT that technically did not have remote start. I have been successful in programming a new key with the remote start option, enabled the remote start in the computer, and it almost works. My last hurdle is the hood ajar switch. I get the horn honk, but then the 'Remote stat aborted, hood ajar' message when I try and use the remote start. I can find the connectors and replacement hood latches with the thing all over the internet, buy my question is: does the wiring for this switch already exist on the car or not? And if not, is there a diagram that shows where I need to start to connect a switch to the proper controlling module? I have looked all around the wiring on the front of the vehicle and did not see anything that looked like the correct connector for this switch. If I can find out where it terminates normally I could add one in, but that information has not been easy to find. I was hoping to avoid paying for wiring diagrams for this one thing (plus I kinda suck at reading them tbh), so here I am. Thanks in advance for any advice or input on this! I know where to get the switch from, But where are you finding the harness that plugs into the switch? I know where the connector is behind the passenger light. But I need the harness that connects from the switch to the wire harness, Please. Quote Link to comment Share on other sites More sharing options...
Dodgems Posted February 28, 2023 Report Share Posted February 28, 2023 The harness is behind the headlight. Just have to unwrap or cut some of the tape off and it should plug into the switch. I used a resistor but it was long enough to reach the hole that is for the switch. The connector I plugged the resistor into looks just like the plug on the harnesses I have seen for sale. Quote Link to comment Share on other sites More sharing options...
edvoyager695 Posted February 28, 2023 Author Report Share Posted February 28, 2023 My switch came in today and I popped it in and now have remote start! The connector on mine was already exposed but the switch was absent, so hardware wise it really was just slide the switch in it's spot and plug it in with the existing plug. Quote Link to comment Share on other sites More sharing options...
edvoyager695 Posted February 28, 2023 Author Report Share Posted February 28, 2023 2 hours ago, AOXOMOXOA said: I know where to get the switch from, But where are you finding the harness that plugs into the switch? I know where the connector is behind the passenger light. But I need the harness that connects from the switch to the wire harness, Please. For me the plug to the switch was already there and no additional harnesses/adapters were needed. I forgot to snap a 'before' picture, but did add a couple here of where the connector comes out in relation to the other grouped wires and the switch, as well as a picture of what the connector looks like (it's not very big but the one picture is just from a shopping website). From what I have read elsewhere if you don't have or need a new connector you can get them on several sites with the search term "20xx dodge journey hood ajar switch connector" or something similar. If you do end up needing to wire one in check out tsteves5's reply above for the wiring diagram. Quote Link to comment Share on other sites More sharing options...
AOXOMOXOA Posted February 28, 2023 Report Share Posted February 28, 2023 1 hour ago, edvoyager695 said: For me the plug to the switch was already there and no additional harnesses/adapters were needed. I forgot to snap a 'before' picture, but did add a couple here of where the connector comes out in relation to the other grouped wires and the switch, as well as a picture of what the connector looks like (it's not very big but the one picture is just from a shopping website). From what I have read elsewhere if you don't have or need a new connector you can get them on several sites with the search term "20xx dodge journey hood ajar switch connector" or something similar. If you do end up needing to wire one in check out tsteves5's reply above for the wiring diagram. oh alright, well my car already has that part in the trunk, cool thank you. so i already have the cable. Quote Link to comment Share on other sites More sharing options...
Hussain Posted August 19 Report Share Posted August 19 On 2/27/2023 at 3:25 AM, Dodgems said: Remote Start Works!!!!! The hood switch harness is attached to the right headlight harness. Mine had the cloth like tape covering it. I installed a 1k ohm resistor. Programmed a new remote with the remote start button. Used Alfa to enable remote start and hood ajar switch present. Reset the rf hub using Alfa. And....It would not work. I could get 1 beep from the horn but that was it. Didn't matter how may times I hit the start button on the remote. It would beep on the 1st press and that's all. Letting it sit for 10 minutes did not help. So I drove around for 10 minutes and shut it off. It works! Cost a new remote from Amazon. $35 and the resistor was maybe 10 cents. I will get the hood ajar switch now that I know it works. Wife is very happy!! Hello, I am new here, just a dumb question. since the wiring diagram shows that this switch circuit (meaning open and close) why would you need a resistor and not just a piece of wire to close the circuit to not trigger the hood ajar warning? I have a DJ and heard some people just keep using the resistor instead of the switch (bypassing). thanks Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted August 19 Report Share Posted August 19 8 hours ago, Hussain said: Hello, I am new here, just a dumb question. since the wiring diagram shows that this switch circuit (meaning open and close) why would you need a resistor and not just a piece of wire to close the circuit to not trigger the hood ajar warning? I have a DJ and heard some people just keep using the resistor instead of the switch (bypassing). thanks Welcome to the forum! ALL vehicles of the Dodge family with remote start incorporate this resisterwhich provides a small electrical signal to the various modules to tell which position the switch is in. for circuit /module protection and such. I would NOT attempt using anything other than the specific required resistor or more preferred hood safety switch which is also the same switch used in the Caravan/ Town&Country vans. Quote Link to comment Share on other sites More sharing options...
Hussain Posted August 21 Report Share Posted August 21 On 8/19/2026 at 9:06 PM, 5rebel9 said: Welcome to the forum! ALL vehicles of the Dodge family with remote start incorporate this resisterwhich provides a small electrical signal to the various modules to tell which position the switch is in. for circuit /module protection and such. I would NOT attempt using anything other than the specific required resistor or more preferred hood safety switch which is also the same switch used in the Caravan/ Town&Country vans. Thanks so much for the reply, also happy to join this amazing community. Quote Link to comment Share on other sites More sharing options...
