Bignosedog Posted December 7, 2020 Report Share Posted December 7, 2020 Hello! 2010 Dodge Journey. I can see from looking at the engine that one of the terminals (negative) has a ton of corrosion (only rust that I can see) and the positive terminal looks great. Questions: 1) Can I access the terminal from the engine or do I have to take the wheel off? Like can I lift the fuse box up to better reach it? 2) Do I have to use a Battery Tender or can I unattach this negative terminal, clean it, and reattach it without having major issues? I don't mind losing radio settings I just don't know if there are more important things that I'm not considering. 3) The other terminal looks great. Can I unattach just one terminal, clean it, and reattach it without dying? From watching videos I know how to normally access the battery through the wheel well. I just don't want to jack the car up and break the POP rivets if I can safely clean this one terminal from above. The battery is completely dead as the doors do not lock/unlock from the buttons on the door handle nor the FOB. Thank you very much for you help and time! It's deeply appreciated. You are helping a young, poor family dodge a trip to the mechanic so truly thank you. Quote Link to comment Share on other sites More sharing options...
Bignosedog Posted December 7, 2020 Author Report Share Posted December 7, 2020 I should add I probably could reach the negative, rusted, terminal without moving the fuse box but the positive side looks a bit harder to reach. If I could just unattach the negative one, clean the heck out of it, and reattach it I would have a neighbor come over and we would jump the car. We tried prior to no avail but I think it's that one terminal that is the cause. Well, fingers crossed. Thank you! Quote Link to comment Share on other sites More sharing options...
Armando G Posted December 7, 2020 Report Share Posted December 7, 2020 Bottom line... if you are going to do this, do it the right way. If you go from the top, there is more to remove than just the fuse box. This might cause more damage and time then jacking the car up and breaking a $0.05 plastic clip. You should probably clean both terminals if you believe that is the cause (tender not really needed). Before putting the tire back, try jumping it and if it doesn't work, you are ready to replace the battery. If it does work, don't put it back completely and run to get the battery and alternator tested. If they say it's the battery, well now you are familiar on how to switch it. I've tried enough shortcuts to know its better to do it the right way. Totally up to you though. 2late4u, OhareFred, larryl and 1 other 2 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 7, 2020 Report Share Posted December 7, 2020 (edited) you dont say om how old the battery is but going into really cold winter your best bet is to replace it when you remove and clean the terminals on the old one..also i use a spray battery terminal protectant after reinstalling the cables it covers the terminal connectors with a red spray ,,,works really great, also dont worry about using a battery tender when changing the battery,and yes just remove the wheel and remove the plastic inner fender to have easy access to the battery still tight but is really the only way,and as said before after getting the battery changed or cleaned have some one check your alt as well////////////P.S have some baking soda and water and a small brush to put on the cable ends and where ever you have corrosion to neutralize it as well CRC 05046 Battery Terminal Protector - 7.5 Wt Oz. Brand: CRC 4.7 out of 5 stars 780 ratings | 23 answered questions Price: $10.19 Edited December 7, 2020 by 2late4u probak118 and Bignosedog 1 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted December 8, 2020 Report Share Posted December 8, 2020 You could try cleaning remote terminals under hood first. Be careful to not arc out positive with a metal tool against any other metal surface. If you then put it on charger and get it close to 12 volts, you might be able to jump start off another battery. The push button start needs close to 12 volts to engage circuit to start car. That’s why it won’t start. However cleaning the terminals right at battery will likely be needed long term. There is no way to access battery from under hood , taking wheel off and fender liner out is only way. Checking alternator also great idea. Bignosedog 1 Quote Link to comment Share on other sites More sharing options...
probak118 Posted December 8, 2020 Report Share Posted December 8, 2020 Have a can of penetrating spray handy and soak and sit a little while - the nut and long bolt that holds the battery in place. Mine was pretty rusted, had to use an air gun and extensions from up top. Bignosedog 1 Quote Link to comment Share on other sites More sharing options...
Bignosedog Posted December 11, 2020 Author Report Share Posted December 11, 2020 There are no shortcuts in life. Problem resolved. I ended up taking the wheel off and cleaning the heck out of that terminal. This time the jump start worked. Yay! I got the alternator and battery checked and both came back fine so I think that one rusted clamp was the cause. Though I've become closer to my Dodge from working on it I will say this is the first time I've owned a car where they've "hidden" the battery and I will never take for granted how easy it is to clean a terminal on most cars. My family is mobile again and it cost me nothing so I am not complaining. Thank you all for your help and for anyone who may read this thread down the road my advice is take the tire off, use a screw driver to lift the center part of the POP rivets and pull that rod out and you can pry the "Molly" part out and reuse them without them damaged. Also, if you still have power steering working you can turn the wheel and remove the panel with the wheel still on. If you are just cleaning a terminal this may give you enough space but if you are replacing the battery that wheel has to come off. I'm no mechanic but I have to say having my daughter and wife thank me and overhearing my wife brag about me sure felt pretty damn good! It's like I got a Gold Star on my Man Card. Thank you all once again for your help and for anyone else coming down the road and reading this it might be a hassle but it's really more just time than anything. Take your car to a battery place afterwards and they'll check your alternator and battery for free and for those who have AAA I guess they can come out and test them as well. Armando G, larryl and 2late4u 1 2 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted December 11, 2020 Report Share Posted December 11, 2020 (edited) Glad you got it done. With out car running you have full manual steering ability. Even on electric assist power steering cars (starting circa 2007ish) you can muscle car to side of road. Although it takes a little effort you can in fact turn steering on Journey without engine running as well. And skip the gym visit for the day. Spray the terminals with the CRC corrrosion spray other posters mentioned. Avoid another no start. Always grab battery terminal with glove after tightening and try and move it. If you can move it; needs more tightening. Edited December 11, 2020 by John/Horace Bignosedog 1 Quote Link to comment Share on other sites More sharing options...
Armando G Posted December 11, 2020 Report Share Posted December 11, 2020 @Bignosedog, yeah that is a good feeling... you're a top dog when you get the Family car fixed. Little grease under the finger nails and maybe a scratch here and there (I digress). Anyway, glad it all worked out and you did it right. Now go enjoy your DJ!!! Bignosedog 1 Quote Link to comment Share on other sites More sharing options...
probak118 Posted December 12, 2020 Report Share Posted December 12, 2020 Nice job bignosedog, congratulations on the man card bonus star LOL I am sure the attached picture will also help others know they can tackle this themselves and save an hour extra in mechanic labour cost. Bignosedog 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 12, 2020 Report Share Posted December 12, 2020 over the yr with my 2011 and now my 2014 journey i replaced all the battery's that i had to except this last time, the shop said they would install it for $10. i said okay, like I really didnt care all the while thinking quick jump on this before he changes his mind....,LOL guess i am getting old.....BUT i did stand there and watched him to make sure there wasn't any problems or mishaps Armando G and Bignosedog 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 22, 2020 Report Share Posted December 22, 2020 5 hours ago, Locosiete said: Glad you didn't try it from on top. Would have been much harder and more chance of grounding a wire by accident. Otherwise glad you got it fixed! Good to hear people are willing to roll up their sleeves and give it a try before just giving up and paying someone else. Many times just a matter of getting your hands dirty and giving it a try. That said if you just can't understand what your doing or how to do it then maybe better left for someone else. Not just for the health of your vehicle but you and your families safety too. I am by NO means a mechanic but am always willing to try it if i think it's within my capabilities. The things that gets some of us is admitting we don't know something, that's when it can get expensive or dangerous. Forums like this are great for asking for help when not sure where or how to start or even just bounce ideas off others when trying to track down a gremlin. Next time if your hands are dirty from working on the car and your wife says wash off the grease. Say "That's not grease... that's Mopar juice baby! ? ? ? @2late4u Walmart doesn't Charge to install batteries purchased from them. That's why i said be my guest when i needed to replace my battery this summer. the Walmart's here in AL wont install a battery for a dodge Journey as i checked yrs ago.because of the location same with Auto Zone or any of the other part stores they will sell you one but wont do the free install... LOL OhareFred 1 Quote Link to comment Share on other sites More sharing options...
Neto Posted December 22, 2020 Report Share Posted December 22, 2020 (edited) 2 hours ago, 2late4u said: the Walmart's here in AL wont install a battery for a dodge Journey as i checked yrs ago.because of the location same with Auto Zone or any of the other part stores they will sell you one but wont do the free install... LOL Not at all sure I would LET them, even if they offered. It would be easy to destroy the inner fender well getting access. (I changed the battery on my 2009 Journey a few years ago - It appeared to still be the original battery, so it had lasted for around 7 years.) Edited December 22, 2020 by Neto Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 22, 2020 Report Share Posted December 22, 2020 actually you are right but also with my dodges and my daughters jeeps i went on amazon and bought a big collection of the plastic fasteners...LOL more than i use in my lifetime as wait till you try to buy just one or two at the parts store they act like they are made of gold think i spent around $ 12-15 but i got plenty of them now and all kinds from the fenders to the windshield covers to the tail lights and some i dont know where the hell i will use them..... Quote Link to comment Share on other sites More sharing options...
