Kristen Victoria Thomas Posted June 8, 2015 Report Share Posted June 8, 2015 I own a 2010 Dodge Journey sxt. My second row seating is causing me some issues. 1. The "tilt n slide" feature does not work on my 60/40 second row, to gain complete access to the third row, only thee slide feature works not the tilt. And 2. On 40 seat slide lever is completely unfunctional, you can pull it but it seems to not be connected to anything so the seat will not slide forward or backwards unless you are using the tilt and slide lever. Please help this is driving me crazy. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 8, 2015 Report Share Posted June 8, 2015 MinE are difficult to move as well. Probably pulling the wrong lever. Welcome to the forum Kristen. Quote Link to comment Share on other sites More sharing options...
rolly Posted June 9, 2015 Report Share Posted June 9, 2015 My rear seats won't slide either. Some have suggested sitting in the seat and using your body weight to force the seat to slide. My seats are already in the far rear position which is okay with me. I've oiled the seat rails and everything. Nothing works. I had to do that to get mine to move. Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 9, 2015 Report Share Posted June 9, 2015 ya they are a little stiff to move but since i don't sit back there.... Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted June 9, 2015 Report Share Posted June 9, 2015 Mine slide fine... Never tried the tilt feature since the third row is always down. Maybe you guys need to hit the gym? jkeaton 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted June 9, 2015 Report Share Posted June 9, 2015 It's not enough room for sex in the back seat so it's worthless to me. While going 118? 11journeybama 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted June 9, 2015 Report Share Posted June 9, 2015 Mine have been stiff to tilt and slide since new. I'm coming up on 1 year of ownership. When I'm taking the kids to Church, they only move to 40 side. I tried the 60 side right after I bought mine. It was very stiff, and I don't believe that it has ever been moved again! Welcome to the forum. I'm not sure if the handles are connected with a cable or bar. Quote Link to comment Share on other sites More sharing options...
rolly Posted June 9, 2015 Report Share Posted June 9, 2015 While going 118? They call that a real quickie! dhh3 1 Quote Link to comment Share on other sites More sharing options...
Kristen Victoria Thomas Posted June 9, 2015 Author Report Share Posted June 9, 2015 I will be taking it to dodge tomorrow to figure it out. I've gotten the tilt feature to work on the 60 side 3 times, by a family member. She was never able to do it again. The slide feature works when I pull the tilt and slide lever, but on the 40 side the "slide only" lever seems to be disconnected, because the "slide only" lever works on my 60 side. Who.e I'm there maybe they can fix the back of my second row, the back of all the seats are coming unclipped. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Kristen Victoria Thomas Posted June 9, 2015 Author Report Share Posted June 9, 2015 It's not enough room for sex in the back seat so it's worthless to me. There should be plenty of room if you lay the 2nd and 3rd row down. Sooooo..... Maybe you don't know how to work the seats and probably should comment on a post about working the seats. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Kristen Victoria Thomas Posted June 9, 2015 Author Report Share Posted June 9, 2015 Tans thank you all for welcoming into the Dodge Journey family. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Milous Posted June 10, 2015 Report Share Posted June 10, 2015 (edited) To make the 2nd row seats easier to slide, this will work in some cases: Loosen the four seat track to floor fasteners, then tighten all four seat track to floor fasteners to 95 Nm (70 ft. lbs.) in the following sequence:a. Front inboard bolt (closest to center console)b. Front outboard bolt (closest to outside door)c. Rear inboard nut (closest to center console)d. Rear outboard bolt (closest to outside door) (See attached file) S1423000033_rear_seats.pdf Edited June 11, 2015 by Milous dhh3 1 Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted June 11, 2015 Report Share Posted June 11, 2015 What the hell does onboard and outboard mean? Left, right? Not all of us were raised on a ship. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Milous Posted June 11, 2015 Report Share Posted June 11, 2015 What the hell does onboard and outboard mean? Left, right? Not all of us were raised on a ship. I edited my original post to clarify, it was Chrysler's wording... Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted June 11, 2015 Report Share Posted June 11, 2015 Oh that makes more sense. I was thinking 4 bolts total, not 4 bolts per seat. Thanks Quote Link to comment Share on other sites More sharing options...
