brake issues, remote start
i just bought a 2010 Joureny sxt and im experiening brake issues such as i got to apply the brakes there there then next time pedal goes to the floor.. Brakes are new, i brought it back to the dealer where i bought it they had it over a week and cant find a problem, and now since i got it back my remote start isnt working. right, it starts my car and in 3 secs it shuts off.
\Can some please help me?
This should be a very easy diagnosis for a dealer service shop... I agree with jkeaton that you should take it to the dealer and actually show them the issue. I find it hard to believe that they would not notice something like this.
When you say the brakes are new, who replaced them and what was done?
  • Official Dodge Support
Hi Shawna,
As jkeaton and Lobitz68 recommended, you should bring your vehicle back to the FCA dealership and try to ride with them in order to show them your concern directly. Also, as bigtsr said, the remote start system may not work if your fuel tank is low. I would have the dealership take a look at that as well because there are multiple possibilities as to why your remote start may have shut down:
Low fuel lamp on or at fuel level of telltale lamp on.
Low Voltage below 11 V
High Voltage above 16 V
Key in Ignition
Doors or hood are opened before remote unlock
Hazard Switch depressed
Panic or theft alarm active
Brake applied
A prior remote start cranked the engine , but failed to start the engine
Battery voltage NOT in the normal range
High (run away) or Low Idle (stall) RPM
MIL Active
High Engine Coolant Temperature
Low Engine Oil Pressure
Remote start allows a maximum of two starts per ignition off cycle; cycling the ignition resets
