walker Posted January 3, 2013 Report Share Posted January 3, 2013 When tires are rotated, do the pressure sensors need to be reset, or do they somehow know where the wheel positions were moved to? Quote Link to comment Share on other sites More sharing options...
Moparman Posted January 4, 2013 Report Share Posted January 4, 2013 They relearn themselves Armando G 1 Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted January 4, 2013 Report Share Posted January 4, 2013 Moparman is right. Drive it around for awhile and they will automatically be detected....your owners manual will give you more info about it. Quote Link to comment Share on other sites More sharing options...
walker Posted January 4, 2013 Author Report Share Posted January 4, 2013 Thanks for the replies. The manual doesn't address the tire rotation question....Unless I missed that part! Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted January 4, 2013 Report Share Posted January 4, 2013 (edited) You're right it doesn't specifically mention the tire rotation but it does mention replacing a tire with info on how long and fast you need to drive for the sensors to automatically detect. I would assume it would also apply to a tire rotation once tires are set to its new location. Once you repair or replace the original road tire and reinstall it on the vehicle in place of the compact spare, the TPMS will update automatically. In addition, the “Tire Pressure Monitoring Telltale Light” will turn off and the graphic in the EVIC will display a new pressure value instead of dashes (- -), as long as no tire pressure is below the low-pressure warning limit in any of the four active road tires. The vehicle may need to be driven for up to 20 minutes above 15 mph (24 km/h) in order for the TPMS to receive this information. Edited January 4, 2013 by Journey_SeXT Quote Link to comment Share on other sites More sharing options...
walker Posted January 4, 2013 Author Report Share Posted January 4, 2013 Yes that addresses putting tthe repaired wheel/tire back in the same location it was removed from. But I would imagine if it can update itself there, it should update for any wheel or wheels. I suppose I could dump some air from one tire to see if it reads the correct location, but I'm just too darn lazy! LOL Thanks for the reply You're right it doesn't specifically mention the tire rotation but it does mention replacing a tire with info on how long and fast you need to drive for the sensors to automatically detect. I would assume it would also apply to a tire rotation once tires are set to its new location. Once you repair or replace the original road tire and reinstall it on the vehicle in place of the compact spare, the TPMS will update automatically. In addition, the “Tire Pressure Monitoring Telltale Light” will turn off and the graphic in the EVIC will display a new pressure value instead of dashes (- -), as long as no tire pressure is below the low-pressure warning limit in any of the four active road tires. The vehicle may need to be driven for up to 20 minutes above 15 mph (24 km/h) in order for the TPMS to receive this information. Quote Link to comment Share on other sites More sharing options...
wolfpup2019 Posted October 1, 2019 Report Share Posted October 1, 2019 I had new tires put on my Journey, now I am getting lots of different pressure readings on the dash panel. Even thought I checked the tire pressures with a new gauge and pressure was correct, I get low pressure on the dash panel for driver side front, then it will change to another tire, or several tires. Is there a way to reset the dash panel. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted October 1, 2019 Report Share Posted October 1, 2019 They should have offered to replace the sensors when changing the tires. You don't mention the age of your vehicle. It could be time to replace them, At any rate, I would take it back to the tire installer and question them. larryl and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
wolfpup2019 Posted November 24, 2019 Report Share Posted November 24, 2019 Now I am getting a message to service tire pressure system. How do I do that. Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted November 24, 2019 Report Share Posted November 24, 2019 By following the advice given to you almost 2 months ago. OhareFred, Armando G, larryl and 2 others 1 1 3 Quote Link to comment Share on other sites More sharing options...
Armando G Posted November 24, 2019 Report Share Posted November 24, 2019 On 10/1/2019 at 4:37 AM, jkeaton said: At any rate, I would take it back to the tire installer and question them. Easy... you paid to get this done, let them figure it out. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
