Bunch of dashboard lights come on and cruise won't work.
Robby
OK, I've had my 2016 Journey SXT AWD about four years now. This issue started a few months back, and got progressively worse (running it showed 13.7v and shut off 12.3v). First start of the day or after it's sitting a while, a bunch of dashboard lights (traction control, emergency brake, and anti-skid lights) come on within about thirty seconds after starting. If I let it run a while then kill and restart, they usually clear.
I replaced the battery a little over a week ago but it's still happening, so what did I do wrong?
1 hour ago, John/Horace said:
Yeah codes, obd11 cheaper scanner not likely good enough. Check engine lights pretty much always disable cruise. How many miles on vehice?
There was a cruise control recall around 2018 , dealer flash update.  Was it ever updated?
I have a cheap one, so I'll clear them and see what pops back up tomorrow morning.  Never seen just a check engine light disable the cruise - only time I've ever seen that is with the ABS (or maybe it's the traction control) light is triggered.
Just under 140k.
No idea.  How would I find out?  The cruise has never given me a problem until this happened.  When I can get the lights to clear, it starts working again.
Edited by Robby
even the parts store usually don't have a good enough scanner to check abs codes at least o'reillys and auto zone couldn't check mine when my abs went bad,,,,,,did you check the alt to see if its working properly and as well have the battery LOAD CHECKED even new ones are not always good enough and make sure the battery clamps are CLEAN and TIGHT as well.that can make a big difference,and yes it is a Hassle to recheck them but at least it is a no cost check just a bit of labor and time
Edited by 2late4u
The cruise control update shouldn't affect cruise working I think.  But it was an important safety fix though. There was an issue with cruise not disengaging when it should. My 2014 journey and ram truck were flashed in 2019 I think. Ask dealer if your vin was done; it's a no charge update flash. Get software up to date first, then go on from there.
https://www.google.com/url?opi=89978449&q=https://www.nhtsa.gov/press-releases/consumer-advisory-owners-certain-fiat-chrysler-automobiles-should-stop-using-cruise&sa=U&ved=2ahUKEwjSzr2Y_o2YAxUHnSsGHZYxFfMQFnoECDAQAQ&usg=AOvVaw2pOpXlF0GqVa2Et6wc8OIZ
Edited by John/Horace
The point about parts-store scanners not reading ABS codes matches what I ran into on my 2016 Cherokee — the lights stayed on and cruise quit, but the free scan showed nothing. Before buying a bidirectional tool, I'm weighing whether the safety recall flash on my VIN was actually done; the dealer says no charge, so that seems like the cheapest first step. I came across this overview while comparing scan tools: TOPDON ArtiDiag900 Lite OBD2 Scanner Review https://pickranked.com/product/topdon-artidiag900-lite-obd2-scanner-review. My uncertainty is whether a mid-range scanner will properly access Chrysler ABS and cruise modules, or if I should just pay for a dealer diagnostic. Anyone used one on a KL Cherokee?
Learn Physics
I bought an OBD link XM+ bluetooth dongle (plugs into the dash OBD connector) and it came with a program that reads codes and other functions that DOES read ABS codes. But I also purchased the AlphaOBD program(but need to have the dongle) that is capable of soo much more and I use that mostly. Neither is very expensive especially if you have a smart phone or tablet or such. I needed to buy a tablet to put the two programs onto. Very pleased with the capabilities of both and particularly like the AlphaOBD for accessing pin codes and programming FOBs.
If you can get code to clear for a bit before it trips again, it's most likely one of your wheel bearing toner rings is bad. They are built into each wheel bearing; so one of the four wheels probably needs a bearing assembly.  They are a wear item, although at 200k miles one of ours is still original.
If you aren't likely going to do a repair like that yourself. Pay a shop to do the scan first and then have them change the assembly. Depending on what code shows. Dealer wheel bearing would be expensive repair; smaller independent shop probably cheaper.
