Robby Posted 10 hours ago Report Share Posted 10 hours ago OK, I've had my 2016 Journey SXT AWD about four years now. This issue started a few months back, and got progressively worse (running it showed 13.7v and shut off 12.3v). First start of the day or after it's sitting a while, a bunch of dashboard lights (traction control, emergency brake, and anti-skid lights) come on within about thirty seconds after starting. If I let it run a while then kill and restart, they usually clear. I replaced the battery a little over a week ago but it's still happening, so what did I do wrong? Quote Link to comment Share on other sites More sharing options...
Dean H Posted 5 hours ago Report Share Posted 5 hours ago Find out what codes you have set. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted 5 hours ago Report Share Posted 5 hours ago Yeah codes, obd11 cheaper scanner not likely good enough. Check engine lights pretty much always disable cruise. How many miles on vehice? There was a cruise control recall around 2018 , dealer flash update. Was it ever updated? larryl 1 Quote Link to comment Share on other sites More sharing options...
Robby Posted 4 hours ago Author Report Share Posted 4 hours ago (edited) 1 hour ago, John/Horace said: Yeah codes, obd11 cheaper scanner not likely good enough. Check engine lights pretty much always disable cruise. How many miles on vehice? There was a cruise control recall around 2018 , dealer flash update. Was it ever updated? I have a cheap one, so I'll clear them and see what pops back up tomorrow morning. Never seen just a check engine light disable the cruise - only time I've ever seen that is with the ABS (or maybe it's the traction control) light is triggered. Just under 140k. No idea. How would I find out? The cruise has never given me a problem until this happened. When I can get the lights to clear, it starts working again. Edited 4 hours ago by Robby Quote Link to comment Share on other sites More sharing options...
