Akthagoon Posted November 30, 2025 Report Share Posted November 30, 2025 So when I bought this car, I had problems with my starter at first because I had a slight oil leak so I changed my starter and it worked for a while until my oil leak got worse and I thought it was the oil pressure sensor so I changed that and that didn’t fix it so I changed the entire oil cooler and since then my car is getting no electrical power whatsoever unless it’s hooked up to another running vehicle through jumper cables. When I try to start it it clicks, I hear the starter engage, but no turnover. What other electrical component could cause my car to be getting no power not even to the power locks or headlights. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 1, 2025 Report Share Posted December 1, 2025 Maybe battery is dead. larryl 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 1, 2025 Report Share Posted December 1, 2025 (edited) so many different fixes BUT without being able to have it checked out we are just guessing,,that said if it was running okay till you replaced the oil cooler??? I am assuming its a 3.6 engine,,,,what is the age and condition of the underside frame, is it rust free, I would assume you have a wiring problems so check all the body grounds for loose or corrosion connections and also check all your connectors to make sure you have good connection also check for broken wires,,,check the fuse block for green crusties under it as well,as mentioned have the battery LOAD CHECKED to see if its in good shape,good luck pull the battery and clean the post after load checking it as well the Journeys enjoy a strong electrical connection and weak batteries make them go ape shit with all sorts of problems Edited December 1, 2025 by 2late4u jkeaton and John/Horace 2 Quote Link to comment Share on other sites More sharing options...
