FedUp7 Posted July 12, 2021 Report Share Posted July 12, 2021 I have a 2010 Dodge Journey SXT that I bought last June. About 6 months ago, I went out to the garage to leave and it was dead. I jump started it and it took right off. Ran fine for the next 2 or 3 days and then the same thing. I had it towed to the shop and they ;put a new alternator on it. I was told by the mechanic when I went to pick it up that it still wasn't starting right and I probably needed a new battery. I purchased the new battery and had it put in. It went fine for about two weeks and then nothing. All cables are securely tightened. When it does this no starting issue, when I put the key fob in and turn it, I can hear a clicking sound coming from somewhere around the firewall. I am so out of ideas with thing. I love it but I am losing my patience with it. Any ideas or suggestions? Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 12, 2021 Report Share Posted July 12, 2021 search the forum for ideas as this has been talked to death about, everything from aftermarket accessories to GPS trackers that havent been removed to every other possible problem,,,probally the resewn the person sold it was this problem...good luck and report back if and when you find the solution for the next poster Armando G and Locosiete 2 Quote Link to comment Share on other sites More sharing options...
Armando G Posted July 13, 2021 Report Share Posted July 13, 2021 What he said ? In addition, go back to that mechanic and tell him to stop guessing at what it might be and to really figure out the problem (there are ways to test the system). You can get guesses from a forum... for free. Locosiete and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
KTM Laranjinha Posted December 30, 2021 Report Share Posted December 30, 2021 Since 2010 that I have Battery problems on my DJ R/T...several AGM batteries replaced...and in my case the problem was one light... please see this post: some posts could be fixed...or we could have a unic post with problems vs solutions. Quote Link to comment Share on other sites More sharing options...
Kristy fields Posted July 3, 2024 Report Share Posted July 3, 2024 I have a 2010 dodge journey that keeps needing jumped to start. I got a new battery, cables, and alternator. What us going on bc I'm out of ideas. Someone please help me Quote Link to comment Share on other sites More sharing options...
larryl Posted July 3, 2024 Report Share Posted July 3, 2024 Probably a diesel if your in Africa...we don't have them here How are the grounding straps? Locosiete 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted July 3, 2024 Report Share Posted July 3, 2024 Most common Journey parasitic load (drain while sitting) is the hands free Bluetooth if you have it. There is a mini fuse in passenger kick plate panel. Called HFM I believe, but the 2009-10 are different. Need a multi meter set it to milli amps and start testing draw. After car is off 3 mins check what draw is on main battery, should be only digital clock and radio presets. So 50-75 ish milli amps. Quote Link to comment Share on other sites More sharing options...
Locosiete Posted July 3, 2024 Report Share Posted July 3, 2024 Mine had an issue where the light in glove box wasn't turning off. Glued a quarter to the door to add a hair more to push in plunger and that helped turn off the light. Used my phone camera to record a video, placed in glove box and let it record a video for a couple minutes. Checked video and sure enough light stayed on even though dash and everything else was off 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 3, 2024 Report Share Posted July 3, 2024 So many different kind of electrical draws can be possible that trying to find out on a blog will almost be Impossible, there are so many components in today's vehicles that unless you are really good with different meters and know where to look or test,,, South main auto on you tube is a great place for info and lately he has been posting about finding electrical problems with different cars,,,makes my head hurt just thinking about how he can do everything that he does..ALL this said you probably need to find a good electrical mechanic shop to chase the problem down. Good luck and please report back on what you find for others that will be looking for their odd ball problem with their Journey Locosiete 1 Quote Link to comment Share on other sites More sharing options...
2011 Journey battery drain Posted January 23, 2025 Report Share Posted January 23, 2025 Also have battery drain on 2011 Journey. Dealer said it is HFM, wants $1400 to replace it. Said this may fix drain but three other down stream modules may also be causing some drain. Total cost is $1800. Anyone have HSM module replaced and at what cost. Is this a fare price. Quote Link to comment Share on other sites More sharing options...
Dean H Posted January 23, 2025 Report Share Posted January 23, 2025 (edited) Find a pull the HFM fuse. Interior fuse box by glove box. Check that your glove box light isn't staying on as well. Edited January 23, 2025 by Dean H Quote Link to comment Share on other sites More sharing options...
Dean H Posted January 23, 2025 Report Share Posted January 23, 2025 This shows the interior fuse box. https://www.startmycar.com/us/dodge/journey/info/fusebox/2011 Fuse #131. HFM Quote Link to comment Share on other sites More sharing options...
John/Horace Posted January 23, 2025 Report Share Posted January 23, 2025 https://www.dodgejourneyforum.com/profile/22067-unclesamautos/ This guy seems legit. Have not personally delt with him, but shipping him your dead unit for a refurb is most cost effective repair. The unit is mounted in dash right underneath steering column. Not easy to get at. There are utube links of people removing it. How long is warranty on dealer repair ? Quote Link to comment Share on other sites More sharing options...
