My backup camera goes black more than it works.  I've already checked the wiring harness so now I'm thinking it's the camera itself.  So a few quick questions:
  1. Does anyone know the OEM part number for just the camera; not the assembly with the lights and the rear hatch handle.
  2. How much is a new OEM camera?
  3. Where can I find a new OEM one?
mine has been doing that lately have a 2014 journey i think its more of a wiring problem than the camera . because it wont work at first or it flickers and then a couple of stops later on it starts working again.. oh well till some one finds the cause we all will be in the dark
14 hours ago, OhareFred said:
Check the wire loom in the rubber boot at the rear hatch.  Common problems with wires breaking
Already checked the wiring loom and found a frayed wire.  I soldered it and retaped it which seemed to fix the flicker, but it's just going black even after the fix.  It works for a few seconds, sometimes, and then goes total black.  That's why I'm thinking the camera??
On 10/14/2018 at 8:57 AM, larryl said:
You could try a auto salvage yard if there is one close to you they might have one and it would definitely be cheaper
Tried that too.  Not only were Dodge Journey's rare in the junkyard, but when I did find one they were completely stripped.  Camera was the first thing to go.
