pacman Posted April 14, 2016 Report Share Posted April 14, 2016 Hi all. I have a '09 Journey SXT with 86000 kms. I can hear a clunk noise (metal) when drive onto a bumper, but if I drive downhill, pressing brakes, it doesn't sound. Rear brake pads aren't new, but I dont't think they need to be replaced yet. Brakes work ok, I mean, I feel car stops without issue when I press pedal. Anybody with similar trouble? Any nut or something like that to adjust? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 14, 2016 Report Share Posted April 14, 2016 (edited) Hi all. I have a '09 Journey SXT with 86000 kms. I can hear a clunk noise (metal) when drive onto a bumper, but if I drive downhill, pressing brakes, it doesn't sound. Rear brake pads aren't new, but I dont't think they need to be replaced yet. Brakes work ok, I mean, I feel car stops without issue when I press pedal. Anybody with similar trouble? Any nut or something like that to adjust? Not sure what you mean by "when drive onto a bumper", but if you are saying you hear a clunk when you drive over a bump it seems it would be more suspension related than brake related. Edited April 14, 2016 by jkeaton rossco and dhh3 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 14, 2016 Report Share Posted April 14, 2016 Does your parking brake work? jkeaton 1 Quote Link to comment Share on other sites More sharing options...
pacman Posted April 14, 2016 Author Report Share Posted April 14, 2016 (edited) Not sure what you mean by "when drive onto a bumper", but if you are saying you hear a clunk when you drive over a bump it seems it would be more suspension related than brake related. Yes, that's what I meant, sorry for my english. I also thought it was something about suspensión, but, if so, why doesn't it sound when I press brake? It's enough to press softly to make noise dissapear. Edited April 14, 2016 by pacman dhh3 1 Quote Link to comment Share on other sites More sharing options...
pacman Posted April 14, 2016 Author Report Share Posted April 14, 2016 Does your parking brake work? Yes, it works pretty ok. I'm not sure if parking brake is the same for automatic and manual gearboxes. Mine is manual, and parking brake is set on pulling up a lever between driver and passenger seats. It's not an electrical parking brake. dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 14, 2016 Report Share Posted April 14, 2016 I would inspect your rear struts, sway bar bushings, muffler mounts, anything that moves. dhh3 1 Quote Link to comment Share on other sites More sharing options...
pacman Posted April 14, 2016 Author Report Share Posted April 14, 2016 I would inspect your rear struts, sway bar bushings, muffler mounts, anything that moves. Thanks for your help. I'll try to check those elements next weekend. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 14, 2016 Report Share Posted April 14, 2016 Possible that one of the rear calipers is loose. That is why you wouldn't hear anything when pushing the brake pedal. OhareFred, pacman and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
pacman Posted April 15, 2016 Author Report Share Posted April 15, 2016 Possible that one of the rear calipers is loose. That is why you wouldn't hear anything when pushing the brake pedal. That makes a lot of sense, and it also sounds dangerous With the car parked but parking brake off, do you think I could move the caliper with my hands? dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 15, 2016 Report Share Posted April 15, 2016 That makes a lot of sense, and it also sounds dangerous With the car parked but parking brake off, do you think I could move the caliper with my hands? You should be able to move the caliper a bit as it is designed to move along the slide pins. dhh3 1 Quote Link to comment Share on other sites More sharing options...
SeanTacular Posted April 16, 2016 Report Share Posted April 16, 2016 (edited) I had this problem on my Sebring. Pad came away from the metal shoe. Pad still had lots of life but for some reason the 2 pcs became unglued and it would clunk over every little bump. Had to buy new rear brake pads and it solved the problem. I could kick the tire while it was parked and make it clunk lol drove me nuts for 5 months till I got a brake inspection and they found the cause. Edited April 16, 2016 by SeanTacular dhh3 and OhareFred 1 1 Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted April 17, 2016 Report Share Posted April 17, 2016 Since we r on the topic of noises here's a new one, last few days I noticed like a click noise slash knock, only sometimes when I'm turning I hear this, brought it to the dealer and they said they didn't hear a thing when the test drove it, so upon picking my journey up from the dealer I was informed that my 2014 blacktop had a recall...apparently moisture gets in the abs system and does something, I forget what it does lol but anyways I got in my car and as I turned out of the parking lot I heard that knock again...I'm mad that it's not fixed I'm going on a trip in may and now I'm hearing something jingling under the car when I go over bumps...that didn't start until i picked up from the dealer...anyone experience this tick/knock in the front end. I personally looked to see if it was something viable but nothing dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 17, 2016 Report Share Posted April 17, 2016 (edited) ABS recall has been around for a year or so. Check the recall/TSB section. Edited April 17, 2016 by jkeaton dhh3 and Cody Chornobey Powley 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 17, 2016 Report Share Posted April 17, 2016 Since we r on the topic of noises here's a new one, last few days I noticed like a click noise slash knock, only sometimes when I'm turning I hear this, brought it to the dealer and they said they didn't hear a thing when the test drove it, so upon picking my journey up from the dealer I was informed that my 2014 blacktop had a recall...apparently moisture gets in the abs system and does something, I forget what it does lol but anyways I got in my car and as I turned out of the parking lot I heard that knock again...I'm mad that it's not fixed I'm going on a trip in may and now I'm hearing something jingling under the car when I go over bumps...that didn't start until i picked up from the dealer...anyone experience this tick/knock in the front end. I personally looked to see if it was something viable but nothing Possibly from your accident the CV joint(s) had too much pressure put on them, and they are beginning to fail. They will definitely click when they start to fail. Check the boots. Look for tares. If the lube/grease begins to leak out, they will soon be toast. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted April 18, 2016 Report Share Posted April 18, 2016 The dealer said everything looked.fine the only thing they did when I brought it in for the noise was fix the abs recall said they did t hear any clicking or knocking dhh3 1 Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted April 18, 2016 Report Share Posted April 18, 2016 This is why I love this forum. Looked under the car seen these all over the boat, didn't see a tear or anything but it's for sure the cv. It goes in Thursday to be fixed. Thanks alot dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 18, 2016 Report Share Posted April 18, 2016 You are welcome. Now for payback, come over to my house and do my headlights! Cody Chornobey Powley 1 Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted April 18, 2016 Report Share Posted April 18, 2016 Hahah. It would be cool if we created a meet somewhere ID love to meet all you guys. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dgncsk Posted August 31, 2018 Report Share Posted August 31, 2018 This is mainly caused by loose brake pad retainers. Quote Link to comment Share on other sites More sharing options...
Neto Posted September 5, 2018 Report Share Posted September 5, 2018 This is an old thread, and the original poster never returned to say what the problem turned out to be, but I have had similar noises on a couple of different vehicles, although not on our Journey. Sometimes the caliper slides become loose enough that the floating side can rotate just enough to bang back & forth against the stops when going over a bump, or through a pot hole. When the brake is just slightly engaged, then the floating part of the caliper is held against the stop, and there is no clunking noise. (The two vehicles I had that did this were a 98 Dodge Neon, and a 98 Chevy S-10.) rossco 1 Quote Link to comment Share on other sites More sharing options...
rossco Posted September 7, 2018 Report Share Posted September 7, 2018 Yup second that, first things I would check would be the calliper slide pins for wear and also "if" these cars have springs in the carriers holding the brake pads then check them too as a pad that can move even 1mm will knock/clunk. Bear in mind to release the handbrake and chock the wheels before checking calliper slides for play as if the handbrakes on it'll lock the calliper and slides into place. Can anyone tell me what brake setup is on the back of these? Are they all disc/pad or are some shoe/drum or both? Rossco Quote Link to comment Share on other sites More sharing options...
Neto Posted September 8, 2018 Report Share Posted September 8, 2018 The way I checked for the caliper issue I mentioned was to jack up the wheel, then have some one engage the brake while I rocked the wheel. You shouldn't be able to move it, but if it does, you'll likely hear the clunking sound. Quote Link to comment Share on other sites More sharing options...
dgncsk Posted November 8, 2018 Report Share Posted November 8, 2018 On 14.04.2016 at 7:10 PM, pacman said: Yes, that's what I meant, sorry for my english. I also thought it was something about suspensión, but, if so, why doesn't it sound when I press brake? It's enough to press softly to make noise dissapear. may be a late reply but , our Jeep Grand Cherokee WK has aftermarket brake pads and retainers are somehow loose compared to mopar branded ones. so when no brakes applied over speed bumps brake pads casue that clunk feel. it sounds like somethign is loose. when i step on brake gently over speed bumps there is no noise. so fix is related to brake pad retainers. Quote Link to comment Share on other sites More sharing options...
