Aftermarket led drl hid projectors
You have to click on the picture. 1 member installed these, that I know of. Around $600. From China. Not plug and play, but a maze of wires. Not for me. I wish that someone here in the states made something for the DJ. I had them on my Nitro with CFL rings.
If you must mess with the lighting, your best bang for the buck is to install true HIR bulbs in the factory reflector.
I have much better places to spend $800 - and then there's the hassle of making them work to consider.
I disagree 1000%. My retro was much less than the cost of these lights and the output is much better than any HIR bulb will ever provide.
OP, I say do the retro yourself. Sounds like you have many of the components already and just need (i.e. want) LED DRL's. The retro is not difficult at all and you will save a ton of cash with better results. The projectors in that unit are low quality and designed for halogens.
Thanks for the tip. I have mini h1 now but I want more. Something better
RX350 projectors with STI clear lens and Osram CBI bulbs is the best setup. The RX350 is pretty much the same size as a MD2S 3.0 projector the kind I used for my retro.
-RX350 with STI clear lens $225.00
-Osram D2S CBI bulbs 5500K $185.00
US funds + Shipping and tax.
"Best" is probably in the eye of the beholder (especially with something like this), but this would be a pretty sweet set up...
