Anyone know Dodge Journey 2013 engine automatic extinguish suddenly
jojogg
Dodge Journey 2013 CVP
When I pressed the brake a little bit hard this morning and causing the bag back fell down from the passenger seat. The engine stopped by itself. And then I ignite the car twice and then the car became normal.
Is this a problem with dodge journey? Should I bring back to the dealer to check it? Does any one have the same problem before? It never happened before.
Any suggestion will be appreciate.
Thanks
The gas is full and I just added it yesterday. It is still under warranty. I am thinking maybe I should bring it to dealer. Perhaps like what you said they can not do anything. Headache
was your gas low? No idea... Being that it is a 2013 and likely has a warranty left on it I would bring it to the dealer. Although they probably won't/can't do anything unless they are able to replicate the failure.
Yes you should pursue the issue with dealership.
It could be related to a faulty ignition system, not many owners
know that if you push and hold the Start/Stop ignition button
while in Drive that the engine will shut down - could be related.
Thnak you
  • Official Dodge Support
Thanks
jojogg,
In this case, I would also recommend getting this to the attention of the dealership in hopes of reproducing the issue.
The Service Dept. will resolve accordingly once more is known about the condition.
Keep us posted if you can.
