Oil change already?
travis9935
So I have a 13' 3.6 bought it last Dec with 26k miles. Had it in last month cause of oil pan leak. So it's been 2k miles now and the oil change due light came on? They said it had a synthetic oil change. The oil is full and mostly clear. Wtf? The 2k miles were 80% interstate miles due to a long trip. If I reset it will it come back on if it thinks it's dirty or was this a mileage reminder from the last oil change?
The oil change monitor wasn't reset after your last oil change and the reason why it came on this soon....just reset it according to the manual instructions and either change it when the message comes back on or better yet keep track of the mileage and change it at the maximum allowable mileage according to the owners manual.
I pay not attention to my oil change light. It comes on at EXACTLY 2,500 miles no matter what. Highway, city, it doesn't matter. I use Mobil 1 and change it every 5,000 I just reset it at 2,500 and when it come back on I know it's at 5grand. Also use my second trip odom to keep track. In my opinion the oil change reminder in the 09 is there to make the dealer $.
  • Official Dodge Support
Journey_SeXT,
I wouldn't recommend waiting until the maximum allowance if for example the vehicle is telling you to change the oil. The indicator system doesn't work at random like some may believe rather calculates all the relevant conditions affecting oil life in said vehicle.
In other words, the manual has a specified maximum allowance but your vehicle may require a change long before this increment.
Journey_SeXT,
Understood but they have new "synthetic oil" with only 2,000 miles (3200 km's) which I highly doubt needs replacement already even if we are talking about severe driving conditions. The oil change monitor from my understanding doesn't monitor the condition of the oil nor does it know what type of oil you are using but based on driving conditions during each interval...is that right? If that's the case then I would just reset the monitor and wait for a mileage interval like 5000 miles to change the oil but not exceeding the maximum allowable mileage in the owners manual that can void your warranty.
Edited by Journey_SeXT
Journey_SeXT,
You are correct in saying that the system cannot monitor the type of oil or the condition.
Essentially, the The PCM continually monitors numerous sensor inputs to determine the duty-cycles to which the engine is being subjected. A pre-programmed algorithm within the PCM then determines when to light up the indicator lamp.
So it's a bit more complicated than one might think however regular oil changes even if every 5000 kms is advantageous.
Journey_SeXT,
Agreed, there is nothing wrong with too frequent oil changes other than it is a waste of money. As I have stated numerous times in the other threads on the subject, I change mine at 6 months/6000 miles using full synthetic and a top quality oil filter. The oil light is never on, but I perform the reset anyway so hopefully it restarts the "clock".
Um yeah my 2012 Avenger 3.6 which I purchased new went on oem oil till 2k. I was paranoid and changed it since it was a "new" motor. Then synthetic mobile 1. That lasted till 10k! Then I switched to Dino oil, that went almost 3k. Then back to synthetic, that had almost 8k on it when I traded for my journey. So I think it must do a pretty good job of calculating oil life. But with this goin on, this was my first oil change that I've had since I've owned it. Why so little mileage? Unless the dealer used Dino vs synthetic, but still that's not alot of miles, considering it was all interstate.
