Does the Journey have a switch to turn on/off the courtesy lights?
WillieB2F15
I have a 2018 Dodge Journey. My interior lights work fine with manual settings but I cannot find out why they will not turn on when the door opens. The owner's manual doesn't say anything about a switch setting to activate automatic interior courtesy lights, however, it does say the lights should come on when the door is open or unlocked with the FOB.
Member 2late4u was saying the rubber boot sleeve between the forward edge of the door to body of the car. it has wires that run from the powered door controls{ windows, mirror , keyless entry, interior lighting when door opened} MAY have a broken wire inside of that rubber sleeve/boot preventing the lights from turning on. You could also double check the lighting settings on the settings screen of the radio/infotainment screen on the center of the dashboard{not the instrument cluster}.
