5rebel9 Posted September 27, 2025 Report Share Posted September 27, 2025 24 minutes ago, 14WhiteRTRallye said: Love my R/Ts YUP the wife's 13 RT has those rims, just not as "scar free" as the pic! Thanks NY winters!!!!! Quote Link to comment Share on other sites More sharing options...
rick2292 Posted November 16, 2025 Report Share Posted November 16, 2025 larryl no not no bs if youd like i can upload pis to show facts not saying all inch rims are the same if u read my post correctly which im assuming you just did a quick glance at it but i did speify that the way it would work is depending on the rims sidewall the one i used had a thick sidewall that when i tried to accelerate i wasnt abl to cuz the rim hit the calliper making it impossible to move if i used a rim with a thinner sidewall yeah youd be correct and id be able to keep calliper on meantime but i didnt have that choice as im sure you did but again if youd like i can post photos or a video showing my proff just saying not all rims are made the same Quote Link to comment Share on other sites More sharing options...
larryl Posted November 16, 2025 Report Share Posted November 16, 2025 No idea what your talking about rick2292 how can tires cause the rim to hit the caliper? If they are off a 13 or newer Caravan or Journey they will fit without hitting I had 19's and put 17's on from a 16 Caravan and they fit fine. They upgraded the brakes in 13 to a larger caliper older wheels won't fit 09-12 for example If the tires were to big you wouldn't be able to put the rim on the hub unless you used spacers You don't need to post a pic cause I don't really care mine fit no problem enjoy your Journey jkeaton 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted November 18, 2025 Report Share Posted November 18, 2025 He said tires, probably meant rims hitting. This is good info for the site. Just came across this same issue for the first time, older 17" dodge rims not fitting over the bigger duel piston 2014 Journey calipers. Rims were off a Caravan, wrecker labeled them (probably incorrectly 2015) and rubbed just enough to not spin. Spacers would move rim off bearing hub center ring, put load just on wheel studs...not a good idea IMO. So I assume all Journey rims are only downwards compatible. All 17, 19 inch rims from 2013-2020 will fit on all years of journey 2009-2020. But 16,17 and 19 from 2009-2012 will never fit on 2013-2020 newer years. I never knew that. Or saw it clearly stated on any tire/rim threads. Is this correct ? Quote Link to comment Share on other sites More sharing options...
