aftermarket radio and backup camera
nt1983
Welcome to the forum. You have to have one of the 2 large screen radios to hook up the factory back up camera. The camera is not compatible withe small screen radios.
Muth makes a universal back up camera, where the image is in the rear view mirror.
Call Crutchfield as far as installing an aftermarket radio. I do not see why a double din radio with a large screen wouldn't fit. Some of them have the connections for a camera.
NAV-TV makes an adapter to let you connect a backup camera to the 4.3 inch display - but it is very pricey.
Do not go with an aftermarket radio unless you don't mind losing a lot of the control over your air conditioning.
Edited by bramfrank
There is a kit that allows you to install an aftermarket stereo in the models with the 4.3 ONLY. Metra makes a kit that retains the touchscreen for use with the other vehicle systems and allows you to install an aftermarket stereo. The kit allows installation of a single DIN or a double DIN (so you can install an aftermarket camera). You would also need the steering wheel controls adaptor, but I think everything else is included. Runs $400-$500 US.
http://www.metraonline.com/part/99-6520B
That is pretty cool that a company would go to all that trouble just for one vehicle.
They have a whole line of them, not just ours... With most manufacturers moving to a similar system, companies will have to react to remain profitable. They are a little pricey though, and the buttons stick out quite a ways.
