The Salmon Posted 22 hours ago Report Share Posted 22 hours ago 2012 Journey info screen went blank. Thought it was the uConnect and replaced it with an OEM, still did not come on.. I was reading somewhere that a faulty ignition switch may cause this as I have at times got the "NO Key Fob" sign even though I had just replaced the battery. Also, the vehicle will not crank or start sometimes and all I need to do is connect a portable charger and it starts right up. Any thoughts on this as a radio and the AC/Heater controls would be a nice addition to have🙂 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted 5 hours ago Report Share Posted 5 hours ago How many miles...which engine in behicle. Journey very finicky for weak battery; charging car fixing issues is not good. Always start with reading codes first. No start could be as simple as a cps sensor. Really a wear item at 100k plus on most cars; only a $30 ish dollar item. Doesn't always store a code though. Cleaning up all the grounds on the car especially struts towers can also help things, my 2cents. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted 2 hours ago Report Share Posted 2 hours ago So.... You have the 3.6 motor and the 4.3" radio screen by previous postings. YES, time to clean the wire ends and studs for the grounds on the driver side strut tower. Then "weather permitting to "dig in" and clean the battery terminals and posts. There are many possible causes to the "blank screen" and ventilation control panel(below the screen), that to give an absolute here's where to go is not really feasable. BUT I do know that from electrical problems I had to "overcome" on my son's '11, that the items you've listed all run thru the TGM. This is what many call the radio module and has the single disc CD player as part of it(for reference of location). The '11 would not shut down the start button, instrument cluster or 4.3 screen, thus draining the battery overnight. A similar year TGM/radio unit from a parts donor car fixed all the issues and was a straight "plug and play" with NO recoding needed. Hard to trace a fault inside the TGM, so if cleaning the grounds as posted does not fix things for you, you may want to find another TGM from a salvage yard DJ. It is NOT DIFFICULT to pull and replace this unit in the center stack of the dash. GOOD LUCK and keep us posted. Quote Link to comment Share on other sites More sharing options...
The Salmon Posted 1 hour ago Author Report Share Posted 1 hour ago 4 hours ago, John/Horace said: How many miles...which engine in behicle. Journey very finicky for weak battery; charging car fixing issues is not good. Always start with reading codes first. No start could be as simple as a cps sensor. Really a wear item at 100k plus on most cars; only a $30 ish dollar item. Doesn't always store a code though. Cleaning up all the grounds on the car especially struts towers can also help things, my 2cents. 174K 3.6... I'll try cleaning up the post, Quote Link to comment Share on other sites More sharing options...
The Salmon Posted 1 hour ago Author Report Share Posted 1 hour ago 58 minutes ago, 5rebel9 said: So.... You have the 3.6 motor and the 4.3" radio screen by previous postings. YES, time to clean the wire ends and studs for the grounds on the driver side strut tower. Then "weather permitting to "dig in" and clean the battery terminals and posts. There are many possible causes to the "blank screen" and ventilation control panel(below the screen), that to give an absolute here's where to go is not really feasable. BUT I do know that from electrical problems I had to "overcome" on my son's '11, that the items you've listed all run thru the TGM. This is what many call the radio module and has the single disc CD player as part of it(for reference of location). The '11 would not shut down the start button, instrument cluster or 4.3 screen, thus draining the battery overnight. A similar year TGM/radio unit from a parts donor car fixed all the issues and was a straight "plug and play" with NO recoding needed. Hard to trace a fault inside the TGM, so if cleaning the grounds as posted does not fix things for you, you may want to find another TGM from a salvage yard DJ. It is NOT DIFFICULT to pull and replace this unit in the center stack of the dash. GOOD LUCK and keep us posted. Thanks, I did find an OEM radio/screen and replaced it, did not solve the issue. I'll start with cleaning the posts, but it needs a new battery anyway. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted 53 minutes ago Report Share Posted 53 minutes ago 43 minutes ago, The Salmon said: Thanks, I did find an OEM radio/screen and replaced it, did not solve the issue. I'll start with cleaning the posts, but it needs a new battery anyway. I'm a bit confused with your response. You replaced just the screen or both the screen AND the TGM/radio(with the CD player in it)? The screen is just like a MONITOR, the working functions it displays come from the TGM/radio. Quote Link to comment Share on other sites More sharing options...
The Salmon Posted 29 minutes ago Author Report Share Posted 29 minutes ago 23 minutes ago, 5rebel9 said: I'm a bit confused with your response. You replaced just the screen or both the screen AND the TGM/radio(with the CD player in it)? The screen is just like a MONITOR, the working functions it displays come from the TGM/radio. Now I'm confused, what are you calling the TCM/radio? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted 20 minutes ago Report Share Posted 20 minutes ago 4 minutes ago, The Salmon said: Now I'm confused, what are you calling the TCM/radio? behind the center stack bezel of the dash. Where you can insert a CD, the 4.3" screen is just that (a monitor screen) power and display comes from that TGM/radio/CD player unit. Quote Link to comment Share on other sites More sharing options...
The Salmon Posted 19 minutes ago Author Report Share Posted 19 minutes ago 8 minutes ago, The Salmon said: Now I'm confused, what are you calling the TCM/radio? SORRY!! So you feel that I should replace the radio/cd, TGM/radio.... Do you feel that this usit could cause my blank screen?? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted 7 minutes ago Report Share Posted 7 minutes ago 8 minutes ago, The Salmon said: SORRY!! So you feel that I should replace the radio/cd, TGM/radio.... Do you feel that this usit could cause my blank screen?? IT is a POSSIBILITY to consider. Take care of the grounds and main battery FIRST. I posted that it is difficult on a forum to tell you the exact cause and fix needed for this situation you are in. So, you only replaced the screen assy. ? Quote Link to comment Share on other sites More sharing options...
