steve38 Posted August 15, 2025 Report Share Posted August 15, 2025 Does anyone know where the turn signal relay is on a 2017 dodge journey? Quote Link to comment Share on other sites More sharing options...
steve38 Posted August 15, 2025 Author Report Share Posted August 15, 2025 I replaced the multi switch on the steering, the bulb, and the bcm, no luck, rear turn signal doesnt work Quote Link to comment Share on other sites More sharing options...
larryl Posted August 15, 2025 Report Share Posted August 15, 2025 have you checked for crimped or broken wires in the hatchback harness? steve38 and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted August 15, 2025 Report Share Posted August 15, 2025 Quote Link to comment Share on other sites More sharing options...
Dean H Posted August 16, 2025 Report Share Posted August 16, 2025 (edited) I need you to provide or confirm this information. Rear turn signal lights not working. 1) Both left and right rear turn signals? 2) Do the brake lights and parking lights work on both sides? 3) Do both front turn signal lights work? There is no relay, the BCM performs the turn signal function. Edited August 16, 2025 by Dean H steve38 and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
Dean H Posted August 16, 2025 Report Share Posted August 16, 2025 (edited) As mentioned previously, check your body to hatchback wire harness. For broken wires. Hatch wiring harness feed https://www.dodgejourneyforum.com/topic/17942-hatch-wiring-harness-feed/ Edited August 16, 2025 by Dean H steve38 and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
steve38 Posted August 16, 2025 Author Report Share Posted August 16, 2025 42 minutes ago, Dean H said: As mentioned previously, check your body to hatchback wire harness. For broken wires. Hatch wiring harness feed https://www.dodgejourneyforum.com/topic/17942-hatch-wiring-harness-feed/ Ok, ty i will take it apart and check. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted August 16, 2025 Report Share Posted August 16, 2025 Was it a used bcm you installed; if new was it aftermarket or factory OEM ? Quote Link to comment Share on other sites More sharing options...
