J'sjourney Posted June 16, 2025 Report Share Posted June 16, 2025 2020 Dodge Journey Dealer says I need brakes and pads. They quoted me a total price of nearly 1700.00 including labor. (Chicago area) Would you take your car to an independent shop or a nationally known shop like Mavis or Firestone? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 16, 2025 Report Share Posted June 16, 2025 I'd buy the parts from a local parts house and do it myself. Not that technically difficult to do. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
J'sjourney Posted June 16, 2025 Author Report Share Posted June 16, 2025 52 minutes ago, jkeaton said: I'd buy the parts from a local parts house and do it myself. Not that technically difficult to do. @jkeaton Thanks. There is no way I could or would try. Not that mechanically inclined and way to old to even try. Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 17, 2025 Report Share Posted June 17, 2025 (edited) just call around the local garages for a check and price for all 4 corners...To be honest you shouldn't need brakes all the way around for a 2020 journey ,of course we don't know how you drive and also the all important question of how many miles are on the journey...brakes on your journey should have lasted you at least 100 k unless they were abused by heavy stop and go driving..... quality brake pads for all 4 corners should be less than 200 plus 4 new rotors price can vary from 200-400 depending where you buy them from,,,check out Amazon for rotors and pads I only use anadarko pads....actually only the rear are a bit more trouble than the front since you have to rotate the caliper piston instead of compressing them like the front Edited June 17, 2025 by 2late4u jkeaton 1 Quote Link to comment Share on other sites More sharing options...
J'sjourney Posted June 17, 2025 Author Report Share Posted June 17, 2025 1 hour ago, 2late4u said: just call around the local garages for a check and price for all 4 corners...To be honest you shouldn't need brakes all the way around for a 2020 journey ,of course we don't know how you drive and also the all important question of how many miles are on the journey...brakes on your journey should have lasted you at least 100 k unless they were abused by heavy stop and go driving..... quality brake pads for all 4 corners should be less than 200 plus 4 new rotors price can vary from 200-400 depending where you buy them from,,,check out Amazon for rotors and pads I only use anadarko pads....actually only the rear are a bit more trouble than the front since you have to rotate the caliper piston instead of compressing them like the front Thanks. I will call or stop by some of the local shops. The car only has about 27,000 miles on it. More stop and go then highway driving. Chicago winters with the salt they put down could make then wear faster. Don't know. Not a mechanic. Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 19, 2025 Report Share Posted June 19, 2025 On 6/16/2025 at 8:54 PM, J'sjourney said: Thanks. I will call or stop by some of the local shops. The car only has about 27,000 miles on it. More stop and go then highway driving. Chicago winters with the salt they put down could make then wear faster. Don't know. Not a mechanic. .only 27 k on it they are trying to rape you, or it has a different story not being told.....definitely go somewhere else even salty weather wouldn't cause that kind of problems,,, I was raised in Mich till I was 21 yrs old moved to Al and I am 72 yrs old as of now Quote Link to comment Share on other sites More sharing options...
J'sjourney Posted June 19, 2025 Author Report Share Posted June 19, 2025 11 hours ago, 2late4u said: .only 27 k on it they are trying to rape you, or it has a different story not being told.....definitely go somewhere else even salty weather wouldn't cause that kind of problems,,, I was raised in Mich till I was 21 yrs old moved to Al and I am 72 yrs old as of now @2late4u Not sure what you mean. 11 hours ago, 2late4u said: it has a different story not being told I have nothing to hide. That is what they said. I am going to find some local repair shop to check the brakes out. I'm the same age as you. Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 19, 2025 Report Share Posted June 19, 2025 1 hour ago, J'sjourney said: @2late4u Not sure what you mean. I have nothing to hide. That is what they said. I am going to find some local repair shop to check the brakes out. I'm the same age as you. what I meant there must be a lot more work or things wrong on your brakes for a $ 1700 repair bill,,didn't mean to offend you,so good luck on whatever you decide larryl 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted June 19, 2025 Report Share Posted June 19, 2025 Exactly....sometimes dealers aren't your friend $1700 sounds fishy.. Quote Link to comment Share on other sites More sharing options...
Bear Down Posted September 17, 2025 Report Share Posted September 17, 2025 On 6/17/2025 at 5:47 AM, 2late4u said: just call around the local garages for a check and price for all 4 corners...To be honest you shouldn't need brakes all the way around for a 2020 journey ,of course we don't know how you drive and also the all important question of how many miles are on the journey...brakes on your journey should have lasted you at least 100 k unless they were abused by heavy stop and go driving..... quality brake pads for all 4 corners should be less than 200 plus 4 new rotors price can vary from 200-400 depending where you buy them from,,,check out Amazon for rotors and pads I only use anadarko pads....actually only the rear are a bit more trouble than the front since you have to rotate the caliper piston instead of compressing them like the front . Brakes are important for all vehicles, whether for daily driving or in demanding heavy hauling services. You should call local garages for a brake check and price for all four corners. For a 2020 vehicle, brakes usually last around 100k miles unless there’s heavy stop-and-go driving. Quality pads and rotors for all corners typically cost between $200-$400. Rear brakes can be trickier since the caliper piston needs rotating. Quote Link to comment Share on other sites More sharing options...
Ellison Brooks Posted September 30, 2025 Report Share Posted September 30, 2025 On 6/17/2025 at 5:47 AM, 2late4u said: just call around the local garages for a check and price for all 4 corners...To be honest you shouldn't need brakes all the way around for a 2020 journey ,of course we don't know how you drive and also the all important question of how many miles are on the journey...brakes on your journey should have lasted you at least 100 k unless they were abused by heavy stop and go driving..... quality brake pads for all 4 corners should be less than 200 plus 4 new rotors price can vary from 200-400 depending where you buy them from,,,check out Amazon for rotors and pads I only use anadarko pads....actually only the rear are a bit more trouble than the front since you have to rotate the caliper piston instead of compressing them like the front. Good advice here—brakes on a 2020 Journey should still have plenty of life left unless it’s seen unusual use. In some cases, factors like heavy hauling or constant stop-and-go driving can wear components faster than expected, so it’s always smart to get a full inspection before replacing everything. That’s solid advice—brakes on a 2020 Journey should last a long time unless driving conditions are unusually tough. Checking mileage, driving habits, and getting quotes from local garages will give the clearest picture before spending on full replacements. Quote Link to comment Share on other sites More sharing options...
