Wheel lug torque specs?
Dale Heintz
use to use that method as well,but sometimes you can actually over tighten them , broke down  and bought a torque wrench,and as said always tighten opposite lug nut til tight then go around in a circle just to make sure you didnt miss one using the torque wrench...also just a bit of advice go to harbor freight and buy a 24 inch breaker bar and a 19  metric deep socket,,, makes loosening  the lug nuts  so easy
