Check Engine Light and TPMS Light On
Hi All!
2015 Journey SXT 15000kms -Check Engine Light and TPMS Light
I went out and started the car yesterday and the check engine light is on. Its solid and seems to be running fine... Gas cap is on securely and no obvious issues besides the TPMS also coming on. It came on a few seconds after the car started stating all 4 tires are low but the 2 passenger tires were mega low at 106kPA. The temp did dip down to frost level which I know will shift pressure but that the pressure should go back up once they warm up. The two drivers side stayed the same low level of 208kPA  but  the two passengers never got above 120 kPA. (The tires all look normal and not flat btw).
Would the TPMS issue cause the check engine light to go on? I have it booked into the dealership tomorrow but would like some sort of scenarios or possibilities before I go in.
Thank you!!!
Your check engine light being on solid is ok until you have the codes
read , without the codes you have no clue where to start trouble shooting.
As far as TPMS alerts first thing to do is bring all tires up to spec reading
as posted on the label attached to drivers side door frame and try driving around ,
it may take 2 - 3 driving cycles.
