How do I know if it's CANBUS?
Not sure what you are trying to do, but the whole vehicle runs on the CanBus system; the only difference being whether it is the High Speed System, or the Low Speed System.  My Nitro was High Speed.  I have no idea what the DJ uses.  This is why item's Sales Codes added have to be added to the build list so that they can be activated.  Nothing is simple anymore.
Edited by dhh3
What I'm wanting to do is to tap in to the exisiting stereo to provide an input to an external processor that I'll then feed in to an aftermarket amplifier. I'd prefer not to buy the PAC-CHY5 if I don't have to but if that's what works so be it.
The harnesses are pretty easy-I've used forward and reverse harnesses to tap in to signal before. I'm just wanting to know if there's anything else i need to be aware of so that it actually outputs signal if it's not under load or throws a code.
