Sunroof Drain Issues
To All, just a little reminder to make you aware it is imperative to keep your sunroof drain holes clear. Recently we have had 4" of rain and yesterday I had a problem after a rain that when I drove water came into my overhead console and dripped whenever I accelerated. braked or turned a corner. When I took it to my dealer today they found a ball bearing sized seed had worked it's way into my right drain hole. They actually had to use a high pressure air hose to remove it, once it was gone my drain hole worked perfectly.
Terry
Edited by Windancer
Weird that your Dealer used a high pressure air hose. My Dealer says never use anything high pressure because you run the risk of separating the drain tube from the water channel. Glad it worked for you. Maybe they have a better way of attaching the hoses now.
Edited by dhh3
