Amp and sub location
The tinker bug is starting again, I have a 2015 Crossroad w/o the premium system. Just trying to get an idea of where the factory amp and sub located. Going to use the factory sub enclosure and replace the sub as soon as I can find out the internal volume. I have an Alpine amp that takes hi level inputs, so that will be enough to run the system. I'll just use the OEM speakers with a midrange crossover on them. Any help will be appreciated.
Cargo area left side to be exact. Each door has a 6x9 speaker and they are crap paper. If you try to put any power to them, they will rip. I replaced mine with 6x9 Alpines because they put out the best bass of all the speakers on display at Best Buy.
If you have 3 rows, you will have to remove the left seat before you can remove the panel.
  • 5 years later...
