Misfire - No Codes
2014 DJ 3.6L 205,000 miles
As part of 200K maintenance, several weeks ago (end of October) and about 500-ish miles ago, I replaced the spark plugs (mopar SP149125AF), vacuumed out 4qts of trans fluid and replaced (Valvoline ATF+4), replaced the serpentine belt, and replaced the engine air filter.
After the maintenance, in the back of my mind I thought the idle might have developed a slight wiggle.  Cut to the chase, this week the car started to studder a lot on acceleration.  It can happen at all speeds, including a hit now and then during idle, but is bad on highway driving accelerations (50+ mph).
I downloaded a copy of APPCAR DIAGFCA for a laptop and am seeing misfires on cylinder #1, but no P codes are triggered.  Below is a small snippet of the scanner log when driving in the neighborhood.  If the weather is good this weekend I'll pop the upper intake off again (ugh) and swap plug #1 with #3 and ignition coil #1 with #5 and see what happens.  If a reseating of the packs and cleaning of the connectors doesn't solve the problem, hopefully the log will show it moved to #3 or #5.  The upper intake seals were replaced with FelPro seals when the plugs were replaced, but I cant rule out a very small vacuum leak causing the misfire.  Although but not likely, I won't rule out TCC / transmission studder either because I touched the fluid.
Please double check me. Cylinder #1 is the back bank closest to the firewall and passenger side, yes?  With cylinder #1,,#3, #5 in that bank closest to the firewall (#1 passenger, #3 middle, #5 driver).  yes?
If the coil pack is bad, due to age and mile, it would probably be a smart move to replace all 6 original coil packs.  Replacement Mopar packs are pricey and being an old car, aftermarket is becoming my friend.  Any specific brand recommendations for ignition coil packs you've used?
I'm only 2 minutes into using APPCAR DIAGFCA and I'm impressed for an inexpensive ($29 + cable) laptop scanner solution.
Thanks.
Since you will have to take the upper intake manifold back off for any work......
   There are a couple of things that COULD BE causing the misfire.
Bad spark plug
Bad coil or "boot"
I have also seen from my friends shop of bad lifter/rocker and camshaft lobe wear causing misfires but no codes. since you'll be that far apart anyway, take the valve cover off and check that out. You may have also been hearing(but not posting) of the infamous "engine tick" the 3.6 motor has a known history of, it is from lifter/rocker wear and when bad enough will damage the camshaft lobe.
Good luck and keep us "posted".
Edited by 5rebel9
Yeah plug, coil or possibly an injector. I had a platinum tip fall off a Motorcraft plug three weeks after replacement once. So look closely at plug electrode. Rare but possible. Higher speed and engine and tranny close to 1:1 ratio so miss becomes most noticable. I think tranny probably fine.
Injectors use to be very rare, but with the newer direct injection (not journeys) Honda/Nissan starting to become more common.
NTK for coils are good, they are part of NGK so make lots of oem parts. Could only change back three under intake which disturbs gaskets, leave front three for later. Coils often last life of vehicle imo.
The high-speed detail is useful — a weak coil often shows up under load at highway acceleration more than at idle, so your swap plan should tell you a lot. I'm weighing a misfire counter of my own on a 2015 Grand Cherokee 3.6, so I've been looking at the LAUNCH CRP123X V3.0 Elite OBD2 Scanner Review https://ratethepick.com/product/launch-crp123x-v3-0-elite-obd2-scanner to see whether its live misfire data is granular enough before spending on it. My concern is that a counter just confirms what you already suspect; the plug electrode check 5rebel9 mentioned seems just as important. Did you happen to hear any tick before the studder started?
