14WhiteRTRallye Posted October 28 Report Share Posted October 28 Looks yellow in pic but is gold, for now... 2late4u and 5rebel9 1 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted October 29 Report Share Posted October 29 Nice, fins act like heat sink for cooling. Drain plug also good. There is usually a round flat magnet in tranny drain pans that stick to bottom of metal pan and collect small amounts clutch metal fur, I would still put it in bottom of new pan. It won't be quite as effective if it floats around, but probably better than nothing. Quote Link to comment Share on other sites More sharing options...
14WhiteRTRallye Posted October 29 Author Report Share Posted October 29 (edited) It has a magnet on drain plug. Smaller, but with the ease of draining it now, it will get more changes. The 93,000 mile magnet wasn't too bad. Probably won't be as much since it is well broken in. Edited October 29 by 14WhiteRTRallye 2late4u and John/Horace 2 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted November 3 Report Share Posted November 3 I have added magnetic drain plugs on a few vehicles. Work great and yeah next fluid dump is easy. Added pan with plug on my ram truck. Not a nice aluminum unit like you used,no fins unfortunately. Fluid changes are cheaper than a rebuild, good mod to do. First fluid change always has more fur from the clutches wearing in I think. The additives still wear out over time, so dump and fills will help. 14WhiteRTRallye 1 Quote Link to comment Share on other sites More sharing options...
