Mcgusto82 Posted July 15 Report Share Posted July 15 Hi guys. Been a minute for me. I have 2012 DJ 3.6 AWD. @ 160k miles. Had it since new. about a month or so ago, after a trans issue I had fixed, I merged on the highway with 70 - 80% throttle, temp started to climb to about 230-232. I controlled it with feather throttle and heat on blast. We got to where we were going and came back with feather throttle. Ever since temp creeps into 232 when going over hills. If the ac is on, temp climbs to 228-230 on flat surfaces. I live half way up a hill. Every time by the time I arrive home temp climbs to 230 -232 so far, engine oil looks clean, coolant filled, tank + cap replaced, thermostat replaced, oil cooler gaskets replaced, and have bled coolant lines several times. note: I rebuilt the thermostat with advanced auto kit, problem got worse so I replaced the the whole thing. the current radiator is 2.5 years old, and the thermostat had been replaced then too. then it had a leak from the radiator. I had used stop leak gunk prior to. center heater core replaced when radiator too. the fan is fine. It runs at slow and fast speeds. there is no oil in the coolant. the water pump seems to spin fine. No rattle, no leak. There are no other coolant leaks. observed: when gauge reads 228-230, With ir temp sensor, top radiator hose : 197 at the thermostat, lower hose: 142-150, random radiator position: 155. cabin heat very hot. At the tank, there is visual flow coming into the tank from small hose on top. top hose feels firm at hot, and releasing cap vents pressure at hot. copilot says inefficient radiator, Gemini says bad coolant flow from thermostat. please help. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 15 Report Share Posted July 15 Just as the PLASTIC T-Stat cover and stat are known to stick open, they can also do the reverse and only PARTIALLY open. I had this happen last summer with our '13 rt, and got the same situation as you have. I spent the $$ for the Aluminum stat housing and stat...NO problem since. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Mcgusto82 Posted July 16 Author Report Share Posted July 16 Thank you for posting. yeah I thought the same thing. But I just replaced it. With a plastic one sure but not a no name brand. A doorman. I still have the old assembly I removed. I’m going to boil it to visually check whether that one was sticking. I suspect not since new one didn’t fix. im starting to think radiator actually. why? Because cabin heat seems to do the truck at helping control it. So the larger radiator should be able to manage it but it doesn’t. But I’ll boil the thermostat first. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 16 Report Share Posted July 16 I never had any luck with trying to do the old school of boiling the stat. And the routing of coolant flow sends flow thru the radiator only after the stat opens, so that if stat does NOT FULLY OPEN you have reduced flow thru the radiator and thus cooler temp reading there with a temp gun and high heat feel thru the heater core. Doorman or any part can fail even if NEW. Quote Link to comment Share on other sites More sharing options...
14WhiteRTRallye Posted July 17 Report Share Posted July 17 (edited) Get a Mahle. Same as Mopar oem. Less money. I bought a Mopar to be safe. It is stamped Mahle. Edited July 17 by 14WhiteRTRallye John/Horace and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
