2015 Dodge journey se 2.4L not starting at all
Brook
The first issue I had with my Dodge Journey was back in August 2025. I wound up having to replace the alternator. After the alternator replacement my battery had low voltage. I kept having to jump the battery every morning to be able to start the car. Recently I’ve been having a misfire in my Cylinder 3 and a low battery voltage code. I replaced the spark plugs and the coil pack. It fixed the misfire code, but it still had low voltage. Wednesday night I jumped the car as usual and it started; I ran some errands. In the morning when my wife jumped the car it didn’t start. I replaced the battery and the starter and it’s still not starting; There was a rapid 3 clicks sound coming from the fuse box area when attempting to start. My Dashboard flickers a bit but eventually dies. Can anyone offer some advice on getting this car started?
I spoke to someone at Dodge and they think it might be an electrical issue. I want to hear if anyone has had any similar issues before I continue investing more money in this car. I’ve only had it for a year.
update got a p0600 code , online says pcm issue....
The electrical system is a major weak point on the Journey.
Read these 2 threads linked below, regarding the Journey's electrical system.
Read through the entire thread carefullyYou need to go over these basic checks.
Concerning the low voltage issue.
I will post information on your code, when I get a chance.
Battery
https://www.dodgejourneyforum.com/topic/18210-electrical-system-fyi-battery/
Ground system
https://www.dodgejourneyforum.com/topic/18374-electrical-system-fyi-ground-system/
Edited by Dean H
Dodge journey service information.
P0600 serial communication link.
-PCM detects internal failure.
-Check PCM connectors and grounds.
Clear codes if it returns,
Replace PCM.
This is the battery negative ground on the right large cable.
The PCM grounds through one of the 2 small studs.
Check these and clean.
