2014 journey sxt radio/ temp controls only work on acc
Hi everyone, first post here and I’d like to start by saying all the information covered on this forum by everyone is awesome! I’m a member of other forums for other vehicles and this forum is definitely in the top few! Now, onto the issue. My wife’s 2014 journey sxt 2.4L is having some issues. On our last trip to CO, during 10 degree weather, the radio didn’t come on during a start up. After looking at all the tips and tricks I pulled the fuse to no avail, disconnected battery over night with no luck and have tried holding the volume and tune, pushing the eject button, putting radio into dealer mode etc.. nothings worked. Fuses are all good, I even went to the extent of removing the radio and opening it to inspect the board, which looks fine. I also went to the extent of ordering another factory radio, matching the same exact model numbers etc, and it does the same exact thing. Anyone have any ideas as to what might be causing this? It’s obviously not a power to radio/ screen problem because it comes on in acc. I doubt dodge would run to separate power wires for acc and run modes. Only thing I can think of to do next is check incoming radio power voltage while switching from acc to run and see what happens. If anyone has any insight or suggestions I’d appreciate it! Thanks all!
You need to have it scanned with a higher level scanner.
One that can communicate with all the modules.
The module that runs the display screen is called the TGW -
Telematics Gateway module.
It has a list of codes for it.
Do this and post the codes. Then, I can check my resources.
Edited by Dean H
Are you thinking it may be the screen? It comes on in acc right away, everytime, with no issue. Would the TGW have any variation from ACC to RUN? I have a high end scanner at work that I will hook up to the vehicle and check modules. I will post any codes I see, thanks!
Btw. The replacement radio also does the same thing. It turns on right away when in ACC, everytime. As soon as you switch to RUN or start the car, screen goes black and all controls are dead. I assumed it may have been a module in the radio but having the same exact problem with a separate “tested” radio is telling me different.
I'm kind of lost with your postings. This is the big screen{8.4"} display and everything works in ACC mode of PTS? Does the screen totally black out and no display/ function in run mode? Do the manual controls work although not being displayed?
I'd think there is another fuse for power in run mode verses acc mode
There are factory service manuals posted on the site here, look it up and find a schematic for radio/information unit.
I've heard of the big screen unit going bad and going blank.whereby you can't see or make changes thru the big touchscreen.
A few more specifics of situation would be most helpful.... keep in touch.
8.4” screen, everything works in acc mode. I don’t have controls of hvac when in acc, which is normal operation. As soon as I switch to run or even start the engine the screen goes and stays black, none of the hvac controls work when in run or with engine running. Every once in a while on start up the screen will quickly flash like it’s coming on but goes off right away. All fuses have been checked and replaced. I don’t think the screen is actually bad because it works just fine in acc mode. There’s something changing in the radio or screen or something when switching to run or starting the car. That’s why my next idea was to monitor power voltage going into the radio when going from acc to run, to see what happens, wether voltage drops off completely, lowers too much to power radio, or whatever it is that’s going on
Welp, kinda took a bypass route. Bought on of the 8 core 9” android radio upgrades and installed it. It turns on wether in acc or run or with engine running. So it obviously wasn’t a power issue I was dealing with. Steering wheel controls work but the hvac control panel is black and doesn’t change hvac functions. I’m also unable to change hvac functions from the screen, due to hvac panel being off I’m sure. Is it common for those panels to go out? Weird thing is hazards, volume knob, radio power button and tune knob work. But none of the hvac controls, and the panel isn’t lighting up.
OK, so maybe I should also have asked. Was the 8.4 SCREEN factory or aftermarket???? And yes the heat control{along with fan and radio} panel can go bad only on partial areas. But not being hooked up at all will cause problems.
On the original 8.4 factory unit under display and settings...there is a option for control screen timeout. I wonder if that was selected as on.
If it was a blank screen only and the entire entertainment system still powered on. Triggering could be firmware issue, but just disabling it could get functionality back. So many buried features on vehicle electronics now, not easy imo.
But if you get the android functioning properly, lots of upside with less flaky... better phone operation. Takes time and maybe outside help.17441297259112056557940483764380.thumb.jpg.e3d94038b243ae572fd9a3728e75c619.jpg
Edited by John/Horace
The original 8.4 was factory. I was wondering if the panel and or climate control module is bad and that’s possibly what kept the screen from coming on in the first place? When the original 8.4 was still installed, in acc mode, I tried the control screen timeout to no avail. Now the 9” android comes on with no issue, wether in run or acc mode. I’m just still having the problem of what seems like no power or partial failure to the climate control seeings how it doesn’t even light up anymore. I’m gonna order a climate control module and see if that does the trick, if not then I will replace the control unit itself… grease up the parts cannon lol
Parts cannon wise, I would do the control PANEL{not the module}  FIRST. Much more common failure component and much easier to replace. Do you have auto temp control or manual adjust control for your DJ?
Ok. I’ll start with the panel first. It does have the auto feature.
As far as checking the codes, the mechanic at my fabrication yard has been out all week and has the scanner locked up with all the other tools. I have a buddy with a really high end snap on scanner that said he could bring it over today. Even with the aftermarket radio installed, the scanner should still be able to see what’s communicating and not communicating correct? I didn’t want the new radio to throw off what the scanner should be seeing and look at it as another potential problem. Thanks for all the responses, they’re a big help!
Yeah, so since screen works with the aftermarket SCREEN . BUT I've read that some don't work well with temp controls. The SCREEN and actual radio from factory are seperate units and why I was trying to get to to SCREEN having failed on the original FACTORY screen. Please get that high end scanner done and check for codes. I would also reinstall ALL factory components and do the scan again. The scrreen and actual radio are not that hard to do, I've pulled and reinstalled a number of times with my stable of DJ's.
I installed the radio myself. Only takes about 15 min to switch everything over aside from the air vent swap, which only takes another 10 min or so. Would the original screen failing also cause the climate control unit to fail/ not have power? With the aftermarket radio, the volume, power and tune knob all work, as well as the hazard light button. Everything else doesn’t work, including the trac control button. I even pulled the climate control panel apart and inspected the circuit boards for damage/ burns but the boards looked fine. Waiting for my friend to get here with the scanner and will go from there. Thanks again!
  • 4 weeks later...
Sorry to leave this post hanging. Had some personal things come up and haven’t been able to work on the car. I was finally able to swap in all the factory parts and hook a high end scanner to it, results below. First pic is right after he cleared the codes and the system rechecked. The second photo is after the car was started. IMG_0242.thumb.jpeg.b16d7d121a05c50a728912efc8a0f662.jpegIMG_0244.thumb.jpeg.ce3498cbef7aaa0aa671945793159dda.jpeg
OK
 My 2011 had a "no dash power off" issue when we got it. I had quite the post about it and what I did to find the cause.
BUT what I did learn when having the center stack out was there is a module basically right behind where the screen sits that controls HVAC functions. With the convoluted way CAN/BUS runs in these cars it is possible that that module may be bad and causing the problem, IF you have access to used parts try replacing that module, but make sure it is one for the auto temp system if that is what your DJ is equipped with.
This is definitely an ODD problem, I've got 3 of these cars{had 4 but sold one off recently} and never had this type of problem.
GOOD LUCK and keep us posted..... and I hope all is now OK on the "other fronts" for you.
