5rebel9 Posted April 27 Report Share Posted April 27 (edited) 43 minutes ago, 2late4u said: no mention if one of the wheels have been hit or bent, I had a brand new journey 2011 came with a vibration ,I tracked it down to one of the rim,s dealer replaced it and fixed the problem I kept rotating front to rear in different variations on the wheels till the vib was almost gone then took it to the dealership and told them what I had done and that the bad rim was one of the rears, they figured out which one and looking at it you couldn't tell just bad from the manufacture You may be on to something here! I took the OP's word on multiple balancings being done and should have revealed a bad rim situation IF the person doing the task watched the tire AND wheel spin. One would not expect to see a bad aluminum rim unless a very noticeable bend from say a curb hit or severe pothole. I did countless tire changes and balances in my day and always watched how the tire and rim for "wobbling" as they spun in the balancer. Also an unusual amount of weight being needed to bring a tire "into balance" should be another "tip off" to a tire or rim problem. My standard was anything over 4 ounces on a passenger car tire was cause for further investigation. My apologies to our metric standard members for not giving the metric equivalent, but I think you will understand the "gist" of my posting. Edited April 27 by 5rebel9 2late4u 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted April 28 Report Share Posted April 28 Some of us grew up on imperial and were made to switch in grade school, when feds brought in metric. I still keep house thermostat in Fahrenheit, finer adjustment. The calculator on our smart phones is great for converting, so 4 ounces is 113 grams. Yeah hate seeing huge weights on a tire. Tire with largest weight usually goes driver rear, farthest from steering wheel. Most weights double marked, here is pick of a 1oz or 28 gram and a 1.5 oz or 43 gram. Four oz would be huge, around 4 inches, but I have seen them used. Quote Link to comment Share on other sites More sharing options...
steve lada Posted April 28 Report Share Posted April 28 10 hours ago, John/Horace said: Sounds like a frustrating problem, at least the stuff you have changed out are wear items. If you keep the car you are ahead. You could paint mark all flange connections where driveshaft bolts up; then index the flanges and bolt together again. Or if you have the old shaft you could try reinstalling it. But before reinstalling another driveshaft try driving the vehicle up to vibration speed. If it’s gone you at least have the source. Driving without shaft may trigger a dash light, some people unplug the connector feeding the rear diff. It’s the coil power source for engaging awd. When changing drive shafts mechanics usually mark current location. But with a new shaft it’s not an option. Some shops do have special vibration analysis tools for trouble shooting tricky problems. I do not have the old drive shaft. the carrier bearing was clearly worn and rusted, and i was certain this problem was solved. not to be...now the mention of shops having a special analysis tool has my attention. I have never heard of such a thing but my eye balls are wide open. my 2015 is soon to be a 2025..............would love to find this to help another guy. I was even gonna go back to the mechanics shop and fill him in in case he ever had one like this. its probably gonna cost me more than the damn thing is worth....but now ..I'm pissed. Quote Link to comment Share on other sites More sharing options...
steve lada Posted April 28 Report Share Posted April 28 you are right about one thing,most are wear parts. so my 2015 is almost a 2025! all of the wheels have been checked many times on a high speed balance machine. John,are you saying try driving without the driveshaft connected? hmmmmmm and letting the front wheel drive take over??? I never would have thought of this. but can this really be done? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted April 28 Report Share Posted April 28 (edited) 5 hours ago, steve lada said: you are right about one thing,most are wear parts. so my 2015 is almost a 2025! all of the wheels have been checked many times on a high speed balance machine. John,are you saying try driving without the driveshaft connected? hmmmmmm and letting the front wheel drive take over??? I never would have thought of this. but can this really be done? Yes it has been done by several people on the site for trouble shooting. Safe, doesnt hurt anything. This facebook link to Royalty Auto Surface(good info site) shows chasis vibration sensors locating problem. Not all shops have this equipment. When I worked as a millwright mechanic before retiring, we had vibration analysis tools. https://www.facebook.com/share/v/1FTMQhM1NF/ 5 hours ago, steve lada said: Edited April 28 by John/Horace Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 28 Report Share Posted April 28 NOT on a dodge journey but the same process to see if your problem is rear end related also this has been discussed here in the forum quite a bit on driving without the awd shaft installed you tube is full of a lot of info check it out Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 28 Report Share Posted April 28 you mentioned........ There was a small impact in aft RH wheel (you can see attached photo) but everything in the rear suspension has been replaced including the shock absorber with new parts. Balancing of all wheels done. All mentioned below parts are new as well: All brake rotors plus servicing of the calipers. Rear RH and front LH wheel hub/bearing Rear RH drive shaft so was the wheel bearing on which this damaged rim was replaced as well???? I see you said it was the same feeling with the 19 inch rims and the 17 inch rims as well that is why I am asking about the wheel bearing ..........good luck Quote Link to comment Share on other sites More sharing options...
steve lada Posted April 30 Report Share Posted April 30 wow that is fantastic information my friend! but first, their are two people with the same problem here mine did not have any impact at all. and all of the parts I listed I see that i forgot to mention all struts have been replaced as well....just to be sure here's the list again. all 4 struts all 4 cv shafts, intermediate shaft,drive shaft with carrier bearing, all brakes and rotors,all hubs and wheel bearings, front steering knuckles with new ball joints, new tie rod ends,rear lower and upper lateral links, new Michelin tires, wheel alignment. crazy huh? I cant wait to try the front wheel drive test. I will keep you posted Thank-You again so much Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted April 30 Report Share Posted April 30 14 minutes ago, steve lada said: wow that is fantastic information my friend! but first, their are two people with the same problem here mine did not have any impact at all. and all of the parts I listed I see that i forgot to mention all struts have been replaced as well....just to be sure here's the list again. all 4 struts all 4 cv shafts, intermediate shaft,drive shaft with carrier bearing, all brakes and rotors,all hubs and wheel bearings, front steering knuckles with new ball joints, new tie rod ends,rear lower and upper lateral links, new Michelin tires, wheel alignment. crazy huh? I cant wait to try the front wheel drive test. I will keep you posted Thank-You again so much Just so I understand better.... you only get this vibration at speeds above 75mph? A bad rim or tire would show up around 50 - 65mph. Thanks to my area, I dare not push speeds beyond 70mph and only in a short passing situation. Is the onset of this vibration felt more thru the steering wheel or from the floor/rear area? AND just how "severe" is this vibration? Is it an annoyance or "OMG" I have to slow down till it goes away???? Quote Link to comment Share on other sites More sharing options...
steve lada Posted May 1 Report Share Posted May 1 from 0to 60 id say no vibration at all. then as I pick up speed its starts to vibrate when I get on the freeway (and I'm around them a lot at 75 to 85.. I usually set cruise at 83) the vibration is not a radical need to pull over or dangerous one at all but very annoying. and constant. picture the water in a glass buzzing in the cup holder. and put that feeling both in the steering wheel and the seat. so yesterday john here suggested I try taking the driveshaft off and driving it. and I did.....I thought for sure this would do it. NOPE! but this test does eliminate the driveshaft being out of balance. now it did seem to be a little easier on the vibrate but I'm not really sure. I need to drive it around for a few more days before I can put a definite yes or no on it. now with the shaft off, the viscous housing is still turning so.....on the list, a few mentioned rear sub frame bushings...on the list, did not replace front lower control arms,on the list. I know you mentioned the wheels but they are not the problem had the looked at by 3 different places.. I have been wrenching cars my entire life. and I'm 68 this one..........I wanna shoot Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted May 1 Report Share Posted May 1 We have VERY SIMILAR backgrounds!!! Actually the viscous coupler is NOT spinning with driveshaft out, BUT the differential IS spinning on the spider gears and ring gear/and bearings. Just like the rear end of any RWD vehicle and why I suggested checking the rear diff gear lube. As I stated, I can't and don't hit the speeds you can{legally}, but I have to question that your vibration MAY be wear in the rear differential. What did the drain plug magnet show like when you "changed out" the diff. fluid? The front PTO also has gear lube and is rather difficult to check/fill. but low on lube or worn can cuase vibration through front floor AND steering. NOTE, both units I would NOT put on a list to just replace with new/reman. units....it would cost more than the car is probably worth. Thanks for clarifying things, I think all here now have a much better understanding of the situation. Keep us posted! Quote Link to comment Share on other sites More sharing options...
steve lada Posted May 2 Report Share Posted May 2 Ok, i will look into the front PTO level . the rear magnet was really clean almost nothing on it at all i was surprised.. the search continues...will keep you posted thanks! Quote Link to comment Share on other sites More sharing options...
steve lada Posted May 3 Report Share Posted May 3 I'm about to fall off of my chair here...I may have found something thanks to your thoughts., I have been driving without the driveshaft in for a few days now. and since you mentioned the viscous coupler does not turn, it only makes sense that the vibration is from the FRONT! So I decided to look into the PTU thing. when I drained it, I was surprised to find that I collected almost 31 ounces of fluid! aaaand my car was still slightly tilted back.( while underneath i noticed the ptu is seeping from the gaskets hmmmm) the drain plug I'd say had some normal sludge build up. I filled her up by way of the vent tube I used a large hypo oiling needle used on my Harley forks. (worked so good) buuut im 2 oz short..no biggie for now. I did not think it was gonna make the diff. entering the freeway....60..no vib..70 no vib im shitting...75...no vibrate!! 80....smoooth as silk. on the way back I let it get to 85-90 and it vibrated just a tad. we have found the culprit! I have only had this car since 2019 and i have no idea how in the hell that case could have been over filled. but it was and it sure seems to be the cause. I still owe it 2 ounces. maybe it will take care of the rest. either way, now I know! I think .hahahah wilI let you know after a few more test rides...fingers crossed 2late4u 1 Quote Link to comment Share on other sites More sharing options...
John/Horace Posted May 4 Report Share Posted May 4 From google Power Transfer Unit (PTU) fluid. 12.7 ± 1.7 fl oz (375 ± 50 ml) Beyond over filled, holy hell 250%. Better than no oil and trashed bearings. Could def create some weird noise and vibration. Its more a less a right angle gear box with straight cut gears…few roller bearings. Should have been spitting out of your vent hose under the hood. That’s the bigger puzzle. Think you found it. Quote Link to comment Share on other sites More sharing options...
steve lada Posted May 4 Report Share Posted May 4 yessir I,m thinking so. not to mention the pressure build up! as I mentioned i saw seeping around the unit but never see oil spots on my drive. I'll get her cleaned up the right amount of oil in and hope the ptu is not too bad off. I will let you know. thanks brother you have been amazing! Quote Link to comment Share on other sites More sharing options...
steve lada Posted May 4 Report Share Posted May 4 ya know, I saw that same fluid formula too.buuuut if you check around its just not right.even here in this forum the case calls for .8 liters. (27-28 oz) so in reality it was only say 3 maybe 3 1/2 oz over full. still it made a tremendous. difference. gonna drive it for a few days and let you know. enjoy your day! Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted May 4 Report Share Posted May 4 Glad you have made major progress ! A lot of work and parts, but now you can start ENJOYING the ride again instead of being ANNOYED. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted May 4 Report Share Posted May 4 Oops good catch on the volume. That could be the 2009-10 model with the 3.5 engine and AWD that turned up. My owners manual doesn't indicate a number for capacity. My personal records show I got around 800 ml both times I dumped our 2014. Slight drip so last time around 50 ml less 75w90. Unit weeps a bit but not dripping on ground, about 165k miles, surprisingly original drive shaft. But lots of other front and rear end parts. Blue loctite on those driveshaft bolts when it goes together. Cheers. Quote Link to comment Share on other sites More sharing options...
steve lada Posted May 6 Report Share Posted May 6 well shit...after a few days of assessing,here's what i got. without the driveshaft on the vibration is much better. then I put the shaft back on and noticeably worse. just to be certain I take it back off right away. sure enough better, but not gone. soooo my thought is, is the driveshaft just magnifying the original vibrate or does the shaft actually make it worse? hmmm. I bought the driveshaft from dorman and it still has warranty, called them and explained that its worse when on. pretty sure they are sending me a replacement. having said this, I believe the ptu is the issue or somewhere there connected. btw thanks for the blu locktite reminder had it covered. but now taken off a few more times I have a new set on the way Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted May 6 Report Share Posted May 6 Seeing how this is such a "touchy" problem, lets back up a bit and do some further "sleuthing. Vibration was there with shaft OUT Vibration was GONE with fresh PTU lube and shaft out Shaft IN and vib. back, but at what speed? How many miles on this ride again? I'm fearing worn PTU or even play in FRONT differential carrier bearings{part of the trans.}. I've always preferred putting my "eyeballs" on a problem to try and access things than over printed word. This is quite the "quandary" to figure out, Good Luck! Quote Link to comment Share on other sites More sharing options...
John/Horace Posted May 7 Report Share Posted May 7 I'm thinking drive vehicle on a hoist. Use a mechanics stethescope or vibration analysis equip and see if ptu or rear diff have the most vibration. Source a used unit from LKQ or remove unit and bring to a rebuiider. Usually too pricy. Could also remove rear diff coupler, see if oil has leaked past pinion seal. People have experienced vibration with the coupler and oil seal failing allowing oil on the normally dry coupling. Postings on this site about that. Used coupling is around $300, often comes with complete rear diff. Quote Link to comment Share on other sites More sharing options...
steve lada Posted Thursday at 01:35 PM Report Share Posted Thursday at 01:35 PM 129.000 mi well taken care of. I know very strange. when I changed out the front ptu fluid,then drove with the shaft out, the vibration was gone up to 80 mph. however, after a few days (shaft still out) the vibration makes its way back at 70 plus but much better with the shaft out. drives perfect from 0 to 60 since the vibration is in the wheel and seat, (shaft out) I Think I can rule out rear end. right now I'm looking to see if there is a way to actually check the ptu itself. is driving on a hoist possible i would think the wheels need to be on a solid surface. anyway. one day next week I am going to visit one of the best mechanical minds I know. I would have done this earlier but this guy is just super busy. Thanks again for your thoughts and ideas. will keep you posted to this nightmare Quote Link to comment Share on other sites More sharing options...
John/Horace Posted Thursday at 10:51 PM Report Share Posted Thursday at 10:51 PM A dynamometer allows running car at speed with the wheels supported. Four wheel supported model for awd. But usually no proper access underneath. That why vibration analysis sensors normally used. A regular hoist with wheels hanging not that great. Can’t run up to 80 mph for sure. Wheels unloaded would affect normal noise creation as well. Quote Link to comment Share on other sites More sharing options...
