2018 Dodge journey gt
Tallguy40
56 minutes ago, Tallguy40 said:
But doesn't explain why I have cold blowing on one side and hot on the other
A broken / bad actuator may have failed in the "hot" position for the passenger side. This is also true for A/C usage as A/C temp is controlled by the blend door actuators. There is a blend door for driver and another for passenger side on models with "dual zone" front temp adjustment{which most all DJ's have}.
IF these are working, then there is the POSSIBILITY that A/C refrigerant is low on charge.
You have been given the correct video and suggestions on what to check first.
well it also could be your heater core, but unlikely since they are a 2 zone core... start with the easier and cheaper blend door actuator first
