Hi.  Has anyone replaced the HFM using their maximum care warranty?  When I read the policy, it's significantly vague to me.  I had a situation where my phone would not connect via Bluetooth.   I did a battery "reset".  That seems to have restored functionality for the time being.   Just wondering if it's worth a 2 hour drive to the nearest dodge service center if it stops working again.
Peace.
dont see anything saying HFM  but was told when i bought mine that it  covered everything electrical,,,,,,here is what my policy says,,,,,,,,ELECTRICAL: Starter Motor and Solenoid; Generator (Alternator); Engine Control Module - (Single Module Engine Controller) (SMEC); Powertrain Control Module; Distributor; Ignition Module; Ignition Coil; Coil Pack Assembly; Voltage Regulator; Horn and Form Num: LM1012 Page: 4 of 10 Horn Pad; Transmission Control Module; All Wiring Harnesses; Electronic Fuel Injection System (excluding clogged injectors); Windshield Wiper Motor; Rear Window Wiper Motor; Wiper Control Module; Manually Operated Electrical Switches; Neutral Safety Switch; Temperature Sending Unit/Switch; Oil Level and Oil Pressure Sending Unit/Switch; Body Computer; Body Control Module; Factory Installed Radio, Speakers and Rear Entertainment Systems (Includes CD and DVD Player); Factory Installed Navigation Systems (excludes navigation disc); Audio Amplifier; Height Adjustment Compressor; Gateway Module; Ignition Module, Factory Installed U-Connect System. NOTE: REMOTE TRANSMITTERS AND HEADPHONES ARE NOT COVERED AT ANY TIME. INSTRUMENTATION: Electronic Instrument Cluster; Amp/Voltmeter Gauge; Fuel Gauge; Temperature Gauge; Tachometer; Oil Pressure Gauge; Turbo Gauge; Speedometer. POWER GROUP: Rear Window Defroster; Power Window Motors; Power Window Flex Track; Power Antenna; Power Seat Motors; Power Door Locks and Linkage; Power Sliding Rear Window Motor and Regulator (Trucks); Power Sliding Door Motors; Power Liftgate; Vacuum Pump. LUXURY GROUP: Keyless Entry Sensors and Receiver/Module; Trip Computer; Message Center; Overhead Electronic Vehicle Information Center; Overhead Electronic Compass/Temperature; Power Sunroof Motor; Convertible Top Motor; Electric Mirror Motor and Controls; Cruise Control Servo; Headlight Door Motor; Concealed Headlamp Module; Park Assist Module; Park Assist Sensors; Back Up Assist Camera; Door Latches; Heated Seat Systems; Factory Installed Remote Start System; Heated Steering Wheel; In-Vehicle Wireless Charging Station; USB Outlets; 120V Outlets.
