2010 journey intermittent starting problems
Hi  My 2010 Journey occasionally has problems starting  I did have the recall for the keyfob ignition issue fixed under warranty but I continue to have the issue.  When the problem occurs I get the following scenarios:
a) turn key on and it tries to start but continually makes the noise like it should when it starts but goes on for several seconds before I turn it off   Then once I try it again it makes the same sound for a second and starts normally
B) try starting the car and it just clicks and does nothing. Sometimes when I retry to restart it it will start after one or 2 more attempts.  When it doesn’t start I have to turn key to “ON” position and put the car in neutral and it will start right away.
I have heard of a lot of different possible causes. Has anyone had this issue and found a fix?
Thanks
