Journey Engine light
Hey everyone,
While driving around this morning car was doing fine. No issues starting and running. Went to get lunch. Got back in the car, Pushed the brake and started the car. Attempted to start but quickly shut off even though all the dash lights and gauges started working.
Turned everything back off, Attempted to start again but then the car started to just continue to crank and crank and crank even though i wasn't touching the brakes or the start button. I hit the start button to stop it. Then the car started up just fine but the check engine light is now on.
How can I check for codes without a code reader. I am in Dallas off 75 and forest lane and my husband has a coder reader in his truck at home. I may swing by autozone on the way home. We are taking the car in tomorrow for the U67 emissions recall that just showed up but would rather not have the dealer work on this just because of the costs.
side note here most part stores have quit reading codes due to the covid virus since they have to lean into the car, that is what i have been told at least. get the codes checked but have to ask how old is the battery,,,,, get it load tested to see if it is pushing correct power. journeys dont like weak batteries ..also have them check your alt at the same time if possible and report back what you find out to be your problem,for others that this might happen to them as well
