Differential and viscous removal
AstralRT
I need to replace the viscous coupler on my 2012 3.6 R/T Rallye AWD and I'm wondering if anyone has any photos, vids or diagrams showing what bolts/clamps I may encounter.
Looking at the viscous unit part diagram it appears there are only 4 bolts mounting the unit to the differential, but that isn't a repair manual diagram so I'm wondering if there are any clamps or hidden bolts the product diagram is not showing?
https://www.moparpartsgiant.com/parts/mopar-bdorc-rear-axle~68058066ab.html?Make=Dodge&Model=Journey&Year=2012&Submodel=&Filter=(E=ERB;T=DG2;M=R%2fT+AWD)
I'll be pulling a used one from a scrap yard so I will have a "practice" run before tackling it on my own but would like to go fully prepared with all the need tools.
Any help from anyone on this would be greatly appreciated.
i believe mechanicalidiot had one installed he said it took like 3 hrs for the install so doesn't sound like a quick grab and go repair, you could go by your local dealership they might be able to give you a heads up on it
