exterior door panel compatibility 2010-2011?
Does anyone know if the exterior door panel for the front drivers side from a 2010 would be bolt on compatible with a 2011? I know they LOOK the same from the outside but are they compatible from the frame and mounting bolts inside?
I have a 2011 with corrosion issues on the drivers door and I'm wondering if I buy a door off a wrecker 2010 model will it be a bolt on replacement? Like can I mount up my interior components from my 2011 door without issue?
