I have spent an hour and cut my hand to ribbons trying to install low beam head light bulbs and have now given up trying to replace the sidelight bulbs!
Is there any easy way to access the headlght clusters to make it easier to change these bulbs? Do I need to take the whole unit out?
No problem with the high beam bulbs :huh: .
Tom.
The passenger side is pretty easy to get to so I think your problem is the drivers side. On my 09, the easiest way to access the bulb is to move the fuse holder under the hood. There are 4 little metal tabs that you push in (2 at a time) and the entire assembly can be moved. BE CAREFUL NOT TO LET THE BATTERY CABLE CONTACT ANYTHING METAL. I cover the metal tabs with a cloth. Once the assembly is loose and moved out of the way, you can reach in and change the bulb. Not really easy, but can be done without removing the entire assembly. Not sure about newer models! Good luck
