SeanTacular Posted February 24, 2016 Report Share Posted February 24, 2016 (edited) Ive always liked the look of trucks or suv's with rims and rubber hanging out the wheel wells like an inch or so. I found these rims that will fit the journey for only $600. 17x8 with offset of +20. offset calculator says they will extend outward over stock by 1.5 inches. My only worry is if it may rub the fender edge when shock is compressed. Ive never seen the wheel come anywhere close to the fender lip or going as far as up and in the fender well. What do you guys think?? Maybe im just nuts! hahaha I also saw a new dodge minivan that had its wheels hanging out an inch+ and it wasnt lifted either so Im thinking this may work. Edited February 25, 2016 by SeanTacular dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 24, 2016 Report Share Posted February 24, 2016 (edited) On the Nitro, inside the back of front wheel wells was something call a "pinch weld". When the guys would do this to their Nitros, they had to take a hammer to this, to flatten it out so there would be no rubbing on full lock turns. I have no idea if the DJ even has a pinch weld! Edited February 24, 2016 by dhh3 SeanTacular 1 Quote Link to comment Share on other sites More sharing options...
Steve_T Posted February 24, 2016 Report Share Posted February 24, 2016 I did some googling when I first got the Journey, looking at options, and as the bolt pattern is the same as my previous Jeep, there are a lot of low offset rims available My favorite site for comparing tire sizes and wheel offsets, is; https://www.rimsntires.com/specspro.jsp Where you can compare factory wheel/tire specs, to others you are considering. Attached picture is not mine, but one I found via google. I was tempted to try my 1.5" spacers on my stock wheels, that I had kept from my Jeep, and with a quick look with a tape measure, the factory wheels would have sat pretty flush with the body/fender. SeanTacular and dhh3 2 Quote Link to comment Share on other sites More sharing options...
SeanTacular Posted February 25, 2016 Author Report Share Posted February 25, 2016 Damn I googled for hours and couldn't find a pic of a DJ with low offset rims. That looks really bad ass. The rims are only $600 and I'm gonna use my original rubber to keep costs low and this pic has me thinking it will work perfectly!! dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Steve_T Posted February 25, 2016 Report Share Posted February 25, 2016 Just make sure the centre bore is correct, you may also need hubcentric rings if it is different. Did you find the rims at a shop, or second hand? If at a shop, they could probably test fit one for you first. Being a +20 rim, it won't stick out as far as you think, it will only be a 20mm difference over your stock wheels. To make them flush with the fenders, or stick out, you will need an offset of 0, or less. Check that link to the tire size calculator I put in my last post, you can plug in the different wheel sizes, offsets, etc to help you pick out your wheels. Just trying to help you out, don't want you to be disappointed after you purchase the wheels. jkeaton, dhh3 and SeanTacular 3 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 25, 2016 Report Share Posted February 25, 2016 What Jeep wheel spacers are you referring to? SpiderTrax makes the best wheel spacers, bar non. They make them for most Jeeps, and they are hub centric. I used them on 2 of my Jeeps. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Steve_T Posted February 25, 2016 Report Share Posted February 25, 2016 On my Jeep I had the Rough Country 1.5", which are also hub centric, and had no issues whatsoever with them. I'm regretting not trying them out on the Journey before selling them. dhh3, SeanTacular and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
SeanTacular Posted February 26, 2016 Author Report Share Posted February 26, 2016 The rims are an inch and a half wider. The offset calculator said it would be 40 mm difference towards the outside of the vehicle and I measured with a tape measure and it will stick out an inch past the fender just like I want. Found them online at a rim shop. Next pay check I'll be getting them on. CB is bigger so I will need rings but I ran my last car with aftermarket rims for a year before I got rings and couldn't really tell the difference even at 150kmph. I will try and find some tho. Just gotta make sure they are pretty cantered when you crank down the nuts. Quote Link to comment Share on other sites More sharing options...
SeanTacular Posted February 26, 2016 Author Report Share Posted February 26, 2016 Found the rims online at a shop. CB is larger so I will need rings but I ran my other car with aftermarket rims with no rings for a year and never really noticed at all even at 160kmph but I will still try and find rings cuz I'm anal so if I can find it I must have it lol. Stock 17's are 6.5" wide and these new rims are 8" wide. The calculator seems off on your link and doesn't equate to 1010tires.com offset calculator and my calculations either. Your site posted says rims would only be .8 inch outwards. Doesn't make sense. First adding extra 1.5 inch to a +40 offset would add 19mm to both edges making the rim 19mm's pushed outwards. Then add 20mm for the lower offset which should push it another 20mm's which equals 39mm which is an inch and a half and that's exactly what 1010 tires says and my brain lol. Am I and the 1010 website missing something? Quote Link to comment Share on other sites More sharing options...
BlindSquirrel Posted February 26, 2016 Report Share Posted February 26, 2016 wouldn't wider wheels ruin your fuel economy due to increased friction? They certainly increase road noise. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted February 26, 2016 Report Share Posted February 26, 2016 I'm thinking of getting some kind off off road rim, hard to find one tho with these 19 inch rubbers dhh3 and SeanTacular 2 Quote Link to comment Share on other sites More sharing options...
Steve_T Posted February 26, 2016 Report Share Posted February 26, 2016 Disclaimer, I'm just trting to help you out!! So, when I eye balled w/tape measure, my 1.5inch spacers, from the edge of my current, stock tires/rims, the spacers would have put my wheels even with the fenders, or flush. Now, 1.5inches = 38.1mm So unless I'm totally offbase and confused, or missing something, you would need at least a zero offset rim, just to put your wheels flush with the fenders. You say you want them to stick out past your fenders, you, again, unless I'm totally out to lunch, should be looking at negative offset rims, like what are used on Jeeps to get the wheels/tires, to stick out past the fenders. Remember, I'm coming from the Jeep world, where my Jk had, I believe 40mm offaet stock wheels, and I put on the 1.5inch spacers to avoid rubbing larger tires at full steering lock, and the spacers barely put the wheels/tires sticking out of the fenders. If my calculations are correct, with the addition of the spacers, I was at about a 2mm offset. I no expert, but have lots of experience over the years with aftermarket wheels and playing with offsets. If I'm wrong, someone please correct me, I just don't want you Sean, or amyone else, to be disappointed after spending their hard earned cash SeanTacular 1 Quote Link to comment Share on other sites More sharing options...
Steve_T Posted February 26, 2016 Report Share Posted February 26, 2016 (edited) I better check the 1010tire calc to see what you mean So, I just checked 1010tires, and I think I'm bang on in my thinking, plugging in stock wheel width and offset, compared to new wheel and offset, says "Extend an extra 39mm" position of the outside edge of the wheel. So essentially, measure 39mm (roughly 1.5inch) out from your current wheel, and that's where your new wheel will sit. Edited February 26, 2016 by Steve_T SeanTacular 1 Quote Link to comment Share on other sites More sharing options...
SeanTacular Posted February 26, 2016 Author Report Share Posted February 26, 2016 I already ruin my own fuel economy with my foot so I could just drive better and increase it with wider rims lol also road noise doesn't bother me. I have aftermarket mufflers with the straight thru design. I also ride a motorcycle with aftermarket straight pipe so I'm pretty deaf haha Cody go down to 17's and you'll find tons of really bad ass rims around $600-$700. Plus off-road rims look better with thicker tires and 17" tires are also cheaper and have waaaay more choice in tread design. And Steve don't get me wrong I'm glad you're helping I was just confused by the difference with that website and my brain and 1010tires website saying something different. Maybe there something missing. I've seen a few ads for 17" journey reps that listed a +35 offset but everyone here says +40 which I was using. I used a tape measure today and 39 mm did out the rim just outside of the fender by an inch. Did you measure yours with 19" rims? There has to be something different. Quote Link to comment Share on other sites More sharing options...
SeanTacular Posted February 26, 2016 Author Report Share Posted February 26, 2016 Ok figure out the difference. Your site is listing where the tire will be. Since I have wide tires on thinner rims and will then be putting them on wider rims the tire will move outwards just a hair less than in inch and my tires are pretty flush since they bubble a hell of a lot being 225 on 6.5" wide rims. When on wider rims the tire will bubble far less. 1010tires just talks about the rim edge moving 1.5 inches out. Lol that was driving me nuts!! Quote Link to comment Share on other sites More sharing options...
Steve_T Posted February 26, 2016 Report Share Posted February 26, 2016 Oh, and just found that black one I posted above, google for; dodge+journey+kmc It brings up a few nice examples of bigger wheels. The black one I posted has 20's, with a 40 offset, probably 9 inches wide. SeanTacular 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 26, 2016 Report Share Posted February 26, 2016 What model Jeep? Some have different hub patterns. Quote Link to comment Share on other sites More sharing options...
Steve_T Posted February 26, 2016 Report Share Posted February 26, 2016 Dave, I traded in my 2011 Sahara Unlimited, same bolt pattern as the Journey. Quote Link to comment Share on other sites More sharing options...
Steve_T Posted February 27, 2016 Report Share Posted February 27, 2016 Sean, where are you located, and on what site did you find the rims? If I can get a set of those for $600, I'd rather do that, and run winters on them, than buying a set of steelies for next winter! SeanTacular 1 Quote Link to comment Share on other sites More sharing options...
SeanTacular Posted February 28, 2016 Author Report Share Posted February 28, 2016 (edited) I'm in toronto and the rims where on kijiji. Seller is "Brampton tire warehouse" .Theres like 6-7 rims like that all just a bit different and all around $600-$700 with tax. I just searched 17" 5x127. I bought a used pair of eagle alloy 140 series black with silver lip in a +2 offset I found yesterday on kijiji. Sticks out nice and far with tires it will be 2 1/4 inches and only $200 Edited February 28, 2016 by SeanTacular jkeaton 1 Quote Link to comment Share on other sites More sharing options...
SeanTacular Posted February 28, 2016 Author Report Share Posted February 28, 2016 Here's the link . http://www.kijiji.ca/v-tires-rims/city-of-toronto/17-eagle-050-alloy-wheel-matte-black-5x5-5-5/1127873427?enableSearchNavigationFlag=true They list all these rims on kijiji in different ads plus a few more. Steve_T 1 Quote Link to comment Share on other sites More sharing options...
Steve_T Posted February 28, 2016 Report Share Posted February 28, 2016 I thought it may have been them. I'm in Ottawa, and they post their ads on kijiji here too. Shipping would be a deal breaker. I've got a couple saved searches, looking for 5x127, 5x5, dodge wheels, etc, I'm sure I'll find a set before next fall, don't want to jump the gun and just 'settle' for steelies. Those rims you got should look great, looking forward to some pics! Quote Link to comment Share on other sites More sharing options...
SeanTacular Posted February 28, 2016 Author Report Share Posted February 28, 2016 (edited) Start planning a road trip! Lol only a 4 hour drive. Would make a great lazy Sunday cruise. I'll post pics as soon as they're on. Edited February 28, 2016 by SeanTacular Quote Link to comment Share on other sites More sharing options...
Steve_T Posted February 28, 2016 Report Share Posted February 28, 2016 Kinda hard to justify a road trip with a wife and three kids, just to pick up a set of rims! Hopefully the taxman is kind again to us this year, we usually get a sizeable return, which allows some funds for toys SeanTacular 1 Quote Link to comment Share on other sites More sharing options...
fac3l3ss Posted March 21, 2016 Report Share Posted March 21, 2016 Did this ever unfold into anything? I'm curious after all of the offset and overall diameter chat if the caliper clearance is going to cause any problems on this style wheel. Although there is enough spacer talk that this may not be an issue Quote Link to comment Share on other sites More sharing options...
